papp101 Posted July 7, 2009 Share Posted July 7, 2009 I bought this car with bilstein's up front, however it has the stock rears. I feel like my suspension is out of balance, but I'm a newb when it comes to car suspension. What could I look for to put on the rear? Not looking for lowering as the snow is a 'yatch here in MN and I need the ground clearance. Would just prefer something that matches the big yellow Bilstein hotties up front. Any info would be greatly appreciated! Link to comment Share on other sites More sharing options...
Th3Franz Posted July 7, 2009 Share Posted July 7, 2009 Bilstein HD's or Koni Sports. are they running stock springs all around too? I run Bilsteins and pinks on my daily driven LGT and in winter I still have enough clearance. It is about a 1.25" drop -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
sicklyscott Posted July 7, 2009 Share Posted July 7, 2009 I would go for the bilstein HD's for the front, at least at that point you have matched dampening. I also believe the koni's are shortened, no? Link to comment Share on other sites More sharing options...
Th3Franz Posted July 7, 2009 Share Posted July 7, 2009 The Bilstein HD's in back would probably bring the damping very close to those up front. I don't think the Koni's are shortened since they should work with stock springs. Perhaps someone can confirm this. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
papp101 Posted July 8, 2009 Author Share Posted July 8, 2009 Thanks for the input all! It's great to hear what everyone else would think, not just me and my inside voice. How do I go about researching which spring rate would be correct for my spirited daily driver ride quality? I'm sure there's an FAQ I'm missing. Link to comment Share on other sites More sharing options...
Th3Franz Posted July 8, 2009 Share Posted July 8, 2009 A lot of people seem to like the Rallitek springs. I like the STI pink springs myself but they are a bit more expensive. Eibach springs are good. The main thing is not lowering the car too much (an inch or so is fine) and getting an alignment afterwards. If you search around this suspension forum you can find reviews for people running Bilstein HD's and different springs. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
