Heat Posted July 7, 2009 Share Posted July 7, 2009 I am stage 1 with tuning alliance. It's the only map I use (base map I think is the correct terminology?). I just had to take my battery out to charge it because someone left my door partially ajar... Do I need to do anything regarding the AP and base map? I thought I saw a post on here about it but couldn't find it again. Thanks in advance. Link to comment Share on other sites More sharing options...
LGT Dave Posted July 7, 2009 Share Posted July 7, 2009 You should be good to go as long as you only had a base map installed. Base maps stay in the ECU memory when the battery is disconnected. Realtime maps get deleted from memory after disconnecting the battery. Link to comment Share on other sites More sharing options...
Heat Posted July 7, 2009 Author Share Posted July 7, 2009 That's what I thought... just being paranoid. Case closed; thanks for the help. Link to comment Share on other sites More sharing options...
