Firepuma Posted December 19, 2011 Share Posted December 19, 2011 ^yes. I have it in mine, even with a 3.5mm jack connection it sounds cd quality. I would nOt hesitate, still one of my favorite upgrades Link to comment Share on other sites More sharing options...
96r50 Posted December 19, 2011 Share Posted December 19, 2011 I just ordered the Leptronix unit from RedFloyd this afternoon. I'm excited to try it out as it looks like a great solution to the lack of auxiliary input on the Legacy. I'm planning to connect a PAC Audio IS75 cable to the Leptronix unit using a "3.5MM Male To 2 RCA Female Y Cable" [ame=http://www.amazon.ca/Cables-Go-3-5MM-Stereo-Female/dp/B00187QK58/ref=sr_1_2?s=electronics&ie=UTF8&qid=1324323832&sr=1-2]like this one[/ame]. This should allow me to play audio and charge my iPhone using only the 30-pin Apple connector, as well as providing a regular 3.5mm plug for any passengers with other types of phones/music players. This all makes sense in my head but I'd be happy to hear from anyone about why this will/won't work before I start the tear-down on my radio! Link to comment Share on other sites More sharing options...
RedFloyd Posted December 21, 2011 Author Share Posted December 21, 2011 It should works flawlessly since there is a groupd loop interruptor built into my auxiliairy module. I'm personnally using this: http://store.griffintechnology.com/autopilot It is less expensive than the PAC unit and uses a standard 3.5mm output jack, so that the wire coming from the aux in module may be used with other devices without the needs of an adaptor. @96r50: I will ship your order today using Canada Post expedited parcel. Hope you will receive it between Xmas and Jan 1st. Link to comment Share on other sites More sharing options...
96r50 Posted December 21, 2011 Share Posted December 21, 2011 Good to know! I liked the idea of the Griffin AutoPilot but I want to keep the install as low profile as possible and just have the two cable (30 pin and 3.5mm) coming out of the centre console as required. Thanks for shipping so quickly! Link to comment Share on other sites More sharing options...
RedFloyd Posted December 22, 2011 Author Share Posted December 22, 2011 I have received an email from Canada Post saying that the package was delivered! That's a quick delivery! Enjoy it now Link to comment Share on other sites More sharing options...
ylime Posted December 24, 2011 Share Posted December 24, 2011 do you have any left? or will you be getting any more in soon? Link to comment Share on other sites More sharing options...
RedFloyd Posted December 24, 2011 Author Share Posted December 24, 2011 yes, units are in stock! Link to comment Share on other sites More sharing options...
JermTheElf Posted December 25, 2011 Share Posted December 25, 2011 Just unwrapped mine! Can't wait to put it in. Seems really simple! Link to comment Share on other sites More sharing options...
Spursbury Posted December 26, 2011 Share Posted December 26, 2011 Just ordered - thanks! Link to comment Share on other sites More sharing options...
epidural Posted December 27, 2011 Share Posted December 27, 2011 how do I order one. Thanks Link to comment Share on other sites More sharing options...
96r50 Posted December 27, 2011 Share Posted December 27, 2011 I have received an email from Canada Post saying that the package was delivered! That's a quick delivery! Enjoy it now I got it the other day. Now I'm waiting for the rest of the wiring I want so I only have to go into the dash once! Thanks again! how do I order one. Thanks Check the first post of the thread. All the info is there. Link to comment Share on other sites More sharing options...
epidural Posted December 28, 2011 Share Posted December 28, 2011 Thanks for the info. I just ordered mine. Looking forward to installing it. Link to comment Share on other sites More sharing options...
Jackco Posted January 3, 2012 Share Posted January 3, 2012 got mine in this past weekend, sounds great! thanks for the quality product and detailed instructions! Link to comment Share on other sites More sharing options...
wac Posted January 3, 2012 Share Posted January 3, 2012 I finally found time to install mine this weekend. I combined this kit with an iSimple IS335 3.5mm jack. I drilled a hole for the 3.5mm jack in the center console next to the power socket. The only trick was I had to snake the IS335 cable through the hole I drilled, plug the IS335 3.5mm plug into the socket on the adaptor, before finally finishing assembling the back plate of the CD stack while inside the car. Everything works well when used with an iPod to audio cable I bought from Ebay. The only thing I noticed is that the Audible audiobooks from my iPod sound a bit distorted even at a relatively low volume level of 4. On the other hand, music tracks sound perfectly fine. It could have something to do with the high gain setting of the adaptor board, the iPod cable, or a combination of the two. Regardless, I'm very happy with this kit, and it's much, much better than the old FM modulator. Link to comment Share on other sites More sharing options...
eightballrj Posted January 6, 2012 Share Posted January 6, 2012 I finally found time to install mine this weekend. I combined this kit with an iSimple IS335 3.5mm jack. I drilled a hole for the 3.5mm jack in the center console next to the power socket. The only trick was I had to snake the IS335 cable through the hole I drilled, plug the IS335 3.5mm plug into the socket on the adaptor, before finally finishing assembling the back plate of the CD stack while inside the car. Everything works well when used with an iPod to audio cable I bought from Ebay. The only thing I noticed is that the Audible audiobooks from my iPod sound a bit distorted even at a relatively low volume level of 4. On the other hand, music tracks sound perfectly fine. It could have something to do with the high gain setting of the adaptor board, the iPod cable, or a combination of the two. Regardless, I'm very happy with this kit, and it's much, much better than the old FM modulator. What high gain setting? Is there a pot that will allow gain adjustment? My Belkin Aircast is distorting terribly with Siri and phone calls. Link to comment Share on other sites More sharing options...
wac Posted January 11, 2012 Share Posted January 11, 2012 What high gain setting? Is there a pot that will allow gain adjustment? My Belkin Aircast is distorting terribly with Siri and phone calls. There are no adjustments available. Sorry. Link to comment Share on other sites More sharing options...
epidural Posted January 12, 2012 Share Posted January 12, 2012 WAC Thanks for posting...your install looks awesome. Just got mine and hope to install it soon Link to comment Share on other sites More sharing options...
azncookie Posted January 12, 2012 Share Posted January 12, 2012 i am interested in ordering one. does it work on the 2004 legacy though? Link to comment Share on other sites More sharing options...
RedFloyd Posted January 13, 2012 Author Share Posted January 13, 2012 i am interested in ordering one. does it work on the 2004 legacy though? unfortunately no. The 2004 head unit is completely different from the 2005+ ones. Link to comment Share on other sites More sharing options...
pillboy Posted January 13, 2012 Share Posted January 13, 2012 Might depend on where azncookie is...2005 was the first year for that generation in the US (and probably Canada), but I believe that gen was 2004 in other parts of the world. It is still ugly. Link to comment Share on other sites More sharing options...
RichR Posted January 19, 2012 Share Posted January 19, 2012 Ordering now! Super stoked! Link to comment Share on other sites More sharing options...
Ninja Nemo Posted January 19, 2012 Share Posted January 19, 2012 I purchased my module back in October and its great. One word of advice for everyone, if you are adding an aux in jack into your center console or elsewhere, consider setting it up so that the module to aux-in is not one single cable. Let me explain... To set up mine, I soldered an auxiliary cable to a aux-in terminal from radio shack following another poster's instructions. The auxiliary cable is connected to the module and terminates in the armrest. It works amazing, but it also means that a single cable runs from the module all the way to my armrest. I now realize that it would be a pain to troubleshoot or revise the wiring as it would require a full dismantling of the radio, center console, and armrest. Having one cable from the module to under the shifter and another cable from there to the armrest would have made future troubleshooting / dismantling much easier. Someone also had the idea of soldering two aux-in terminals end-to-end so that the aux-in cable could merely be plugged in which could also help make it easier to dismantle in the future. Besides that, I'm really happy with it. The auto-detect doesn't really work for me, but then again, I wouldn't use it so I couldn't care less. I would happily buy this again and recommend it to all. Link to comment Share on other sites More sharing options...
RedFloyd Posted January 20, 2012 Author Share Posted January 20, 2012 Ordering now! Super stoked! Your order as been received and will be processed Monday, I'm so busy this week! Please apologize for the delay. Link to comment Share on other sites More sharing options...
RichR Posted January 20, 2012 Share Posted January 20, 2012 No problem. I'm out of town the first part of next week so the timing should be perfect! Link to comment Share on other sites More sharing options...
azncookie Posted January 20, 2012 Share Posted January 20, 2012 Might depend on where azncookie is...2005 was the first year for that generation in the US (and probably Canada), but I believe that gen was 2004 in other parts of the world. well i live in Canada and i got my car when it was sometime in Oct 2004, so I'm actually not quite sure whether it's 2004 or 2005... Link to comment Share on other sites More sharing options...
