Salle071 Posted June 30, 2009 Share Posted June 30, 2009 Hello, my driver side window seems looser than others when the door is open. There is some play when pulled back and forth at the top. I guess because it is open so much more frequently than others. Has anyone taken this apart and tightened? I am assuming some kind of bottom glass mount has gotten loose. Hints appreciated, thanks. Link to comment Share on other sites More sharing options...
Osei Posted July 1, 2009 Share Posted July 1, 2009 Not sure what you mean by loose. Are you getting noise, air or water? Year? Top or bottom? Searching will find a recent post on replacing trim at top of door frame to cut down on gap. The dealer( or knowledgeable mechanic) can make an adjustment at the top trim piece to cut down on noise. Just remember to close the door by pushing on the door, not the glass. O. Link to comment Share on other sites More sharing options...
clark687 Posted July 1, 2009 Share Posted July 1, 2009 i no. i have the same problem theres two clips inside one may be broke happen in my 09 get it checked Link to comment Share on other sites More sharing options...
