FloydLegacy Posted June 18, 2009 Share Posted June 18, 2009 My roommate has a 93 legacy wagon and the back door handle won't work. Is there a way to get to the latch and replace it? Either from the outside or inside the car? We really need to get it work. Its kind of pointless having a wagon and only being able to use 4 doors. Link to comment Share on other sites More sharing options...
c-lo Posted June 18, 2009 Share Posted June 18, 2009 post in the older legacy performance section. you may find more help there. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
ehsnils Posted June 18, 2009 Share Posted June 18, 2009 Thread moved. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted June 18, 2009 Share Posted June 18, 2009 I don't know if your issue is similar to mine, but as of a few weeks ago, just unlocking the doors isn't enough to open the tailgate. I hear the mechanism moving, but it seems as if it's JUUUST not quite enough because I have to put the key in and turn it a bit more before I can open the trunk. Otherwise pulling the handle does nothing. Mine's a 98 though. Link to comment Share on other sites More sharing options...
Bdubs Posted June 18, 2009 Share Posted June 18, 2009 The handle is probably rusted out, preventing it from grabbing the latch. It happens, and is common in the first 2 generations of the wagons. You can replace it fairly easy. Access it by removing the interior panel on the hatch, and remove the two bolts. I think it's like $20 for a new one. Link to comment Share on other sites More sharing options...
