armax1980 Posted June 17, 2009 Share Posted June 17, 2009 How would a AVO axleback mufflers sound on a 2.5i with stock everything? Not looking for power just a little bit more rumble to the exhaust. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 18, 2009 Share Posted June 18, 2009 It would sound like trash hahaha not really but it would sound like a honda with an AVO axleback with the stock EL header you gets no rumble in the jungle Link to comment Share on other sites More sharing options...
seanrose Posted June 22, 2009 Share Posted June 22, 2009 it would sound like every other import..... Link to comment Share on other sites More sharing options...
armax1980 Posted June 23, 2009 Author Share Posted June 23, 2009 darn Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 23, 2009 Share Posted June 23, 2009 darn yeah it is a bummer but get you a RS style header and get a mid pip fabbed to fit to the AVO and you will have a mean sounding car. Link to comment Share on other sites More sharing options...
seanrose Posted June 24, 2009 Share Posted June 24, 2009 at that point since your already fabbing stuff up just get like magnaflows or something Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 25, 2009 Share Posted June 25, 2009 at that point since your already fabbing stuff up just get like magnaflows or something 1. Since you need a header and that wont fit anything you have under your car you can go all modified exhaust tubing have it bent to fit around the rear diff and a y pipe to split flow to your stock muffler locations. This method can be had for less if you shop around for your parts i.e mufflers, pipe, HFC, flanges, flex joint. If you buy all the parts ahead all you will be paying for is labor and normally if you go to a local shop not a chain like Monroe or Mieneke *sp they will do it for a flat price 2. You still need the RS style UEL Header but you can keep what you have and fabb that to fit. This isnt a bad method b/c your stock piping is HUGE and more durable than some mild steels used by exhaust shops. Get your header and have them mod your stock mid pipe to mate to the RS header. then get your two mufflers of choice welded to you stock angle flanges and go from there. With both methods you still need to extend your O2 sensors and move your cat. I like the first method because you keep the stock system intact if you need to bolt it back on for service or to sell it of you get tired of it you can b/c youll have two bolt on systems for your car. The first can be done for under $500 with labor if you find a good shop. The second can be done for under $300 and that is due to the header and mufflers. Also in both you will want to extend your o2 yourself via adding wire or buying an extension. Link to comment Share on other sites More sharing options...
OhBe1 Posted June 25, 2009 Share Posted June 25, 2009 Back to the original question - I'd assume only slightly louder, little or no difference in tone. And looking a lot better. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
