RdiggA Posted June 12, 2009 Share Posted June 12, 2009 My friend has an 05 LGT with MR Headers, MR Catless DP, Borla CBE, Perrin 100% Recirc. Valve, K&N typhoon with a TA TMIC and TA Stage 2 E - Tune. He thought the car has been running a little off latly so today we took two logs. It was about 65 degrees out when these were pulled. For all you Logging guys, how do these look?romraiderlog_20090611_112939.csvromraiderlog_20090611_113053.csv Link to comment Share on other sites More sharing options...
fishbone Posted June 12, 2009 Share Posted June 12, 2009 I'm very green at this and still learning, so I'm going to throw out there what I think I see and be corrected by others cause that's how you learn. I think there's some knock based on the fact that knock sum increased from 5 all the way to 10. Knock sum increments for every isolated knock event. Had it stayed at 5 it would have been different. Log FBKC and FLKC Don't know WTF happened in the first log, boost never did go over 2? Link to comment Share on other sites More sharing options...
RdiggA Posted June 12, 2009 Author Share Posted June 12, 2009 +1 for me too, im still trying to learn whats normal/bad for the different parameters. Link to comment Share on other sites More sharing options...
Spec B Posted June 12, 2009 Share Posted June 12, 2009 You should not do any more WOT runs and email TA and send them your logs...you are knocking a ton. You need a revision to that map ASAP. A good tune should not knock at all at WOT. Have you changed fuel or anything else since your tune? Link to comment Share on other sites More sharing options...
Spec B Posted June 12, 2009 Share Posted June 12, 2009 What is weird is your first run is completetly knock free...the 2nd one is horrible?! Link to comment Share on other sites More sharing options...
RdiggA Posted June 12, 2009 Author Share Posted June 12, 2009 its not mine its my friends, he hasnt changed anything. Link to comment Share on other sites More sharing options...
RdiggA Posted June 12, 2009 Author Share Posted June 12, 2009 he is running a LWFW but that only causes low RPM knock correct? and yeah that is weird these logs were takin within minutes of eachother. Link to comment Share on other sites More sharing options...
fishbone Posted June 12, 2009 Share Posted June 12, 2009 What is weird is your first run is completetly knock free...the 2nd one is horrible?! That's what I thought too, kock sum stayed at 4, but where did his boost go? From what I have read, the knock sensor is useless at low rpms where it will THINK it picked up knock events. I think I've seen "knock" even at idle a couple of times. Link to comment Share on other sites More sharing options...
RdiggA Posted June 12, 2009 Author Share Posted June 12, 2009 by mistake i recorded the first log on BAR for boost instead of PSI. Link to comment Share on other sites More sharing options...
fishbone Posted June 12, 2009 Share Posted June 12, 2009 That makes sense, didn't think of that. Crappy gas? What grade and what station? Link to comment Share on other sites More sharing options...
Spec B Posted June 12, 2009 Share Posted June 12, 2009 Low level false knock is pretty common...but above 3000 RPM the knock sensor is pretty good. Link to comment Share on other sites More sharing options...
RdiggA Posted June 12, 2009 Author Share Posted June 12, 2009 93, not sure on where he filled up but wherever it is maybe its time to switch. Link to comment Share on other sites More sharing options...
fishbone Posted June 12, 2009 Share Posted June 12, 2009 That log needs to be revised by the tuner regardless if it is really knocking on 93 octane, barring some really really crappy gas he got. Be happy you have 93, here in Nebraska we have raccoon piss that they call 91 octane. Link to comment Share on other sites More sharing options...
Infamous1 Posted June 13, 2009 Share Posted June 13, 2009 What is weird is your first run is completetly knock free...the 2nd one is horrible?! Looks like the IAM wasn't at 1 yet on the first log. You can tell by the timing that is being called for in the 1st log vs the 2nd. Link to comment Share on other sites More sharing options...
Spec B Posted June 13, 2009 Share Posted June 13, 2009 Ahh... Link to comment Share on other sites More sharing options...
