Jduke Posted March 7, 2005 Share Posted March 7, 2005 Hey , Just did my first oil change on my 05 GT... bought a case of filters and crush washers. All was perfect untill I could not see any crush washer on the drain plug? I though maybe it was crushed and stuck on the bolt or the oil pan, but it was not there. Anyone else notice this? I checked both places very carefully several times and there was no washer there... Finished up without a new washer only becasue I still though there was a chance the old one was stuck on there either to the plug or the pan... no leakage problems so far... but do you think it came from the factory without a crush washer? Thanks for your time. John D. Link to comment Share on other sites More sharing options...
edmundu Posted March 7, 2005 Share Posted March 7, 2005 The factory crush washer is painted black along with the drain bolt, so it might appear to be missing, when it in fact is there on the bolt. This happened to me when I first changed the oil. I then finally noticed it on the bolt. Took a bit of prying to get it off, too! Link to comment Share on other sites More sharing options...
kanoswrx Posted March 7, 2005 Share Posted March 7, 2005 yeah, the first one is hard to see and get off, but its deffinetly going to be there. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 7, 2005 Share Posted March 7, 2005 It's there- like said above, it's painted on- I had to use a small screwdriver to get it off. Link to comment Share on other sites More sharing options...
Jduke Posted March 7, 2005 Author Share Posted March 7, 2005 Yea... guess Ill have to wait till next oil change... I did try and pick and the edges with a thin flathead but did not see where something would come off. Nice to know its did most likely have one, and there is one on there now... should be fine till next oil change, reused a couple when i had my wrx with no problems... John D. Link to comment Share on other sites More sharing options...
iuksob03 Posted March 7, 2005 Share Posted March 7, 2005 Just get a fumoto valve and not have to worry about it. Link to comment Share on other sites More sharing options...
davester_exallroad Posted March 7, 2005 Share Posted March 7, 2005 Jduke, My first oil change it was painted yellow to the drain bolt. I used a razorblade to pry it off and install a new one. If it isn't get one from the dealer ~$1. Link to comment Share on other sites More sharing options...
Jduke Posted March 7, 2005 Author Share Posted March 7, 2005 ah a razor blade... Ill need to remember that next time. I bet that would have worked... Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 7, 2005 Share Posted March 7, 2005 Just get a fumoto valve and not have to worry about it. I thought there were fitment problems with those on these cars Link to comment Share on other sites More sharing options...
iuksob03 Posted March 8, 2005 Share Posted March 8, 2005 I thought there were fitment problems with those on these cars Mine threaded on fine. I've had it for about 8500 miles and no problems so far. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 8, 2005 Share Posted March 8, 2005 Link to comment Share on other sites More sharing options...
