c-lo Posted June 7, 2009 Share Posted June 7, 2009 I get this code periodically when going up hills. usually just a blinking cruise. today a blinking cruise with the check engine light on. After I cleared it I noticed when I started my car it idled pretty low. assume this is normal and the sensor needs to be replaced. if not mistaken, this is behind the passenger side wheel well no? just remove the wheel well enclosure and how easy to replace? any special tools or steps needed to follow? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
blackfang Posted June 8, 2009 Share Posted June 8, 2009 The Air Fuel sensor is on the exhaust, before the cat. Sometimes you can get to them from on top of the engine as it is located on that part of the exhaust on some of the cars is in the lower front of the motor. Some are under the car on the right hand side. You probably could get it through the wheel well. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
c-lo Posted August 29, 2009 Author Share Posted August 29, 2009 so I'm getting this code again. time to replace this sensor. anyone know how much this part is? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Regal05LGT Posted August 29, 2009 Share Posted August 29, 2009 The front o2 sensor is in the exhaust manifold near the UP connection iric....and I think it costs a little over $100 Link to comment Share on other sites More sharing options...
mwiener2 Posted August 29, 2009 Share Posted August 29, 2009 How do you know it's a bad sensor and not a poorly running engine? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
c-lo Posted August 30, 2009 Author Share Posted August 30, 2009 I've had the issue for a while. when it through a code several months back I took it to my mechanic. he read it and came up with the same code. each time I've read it with a reader it's been the same p1153 code. is there something else I should be looking at? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
c-lo Posted August 31, 2009 Author Share Posted August 31, 2009 just ordered from Ryan at Fred Beans! anything special I need to do after I replace this thing? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
