Joey2146 Posted June 7, 2009 Share Posted June 7, 2009 Under hard braking, my car pulls to the right, anybody have any idea why? Link to comment Share on other sites More sharing options...
Platinum_Racing Posted June 9, 2009 Share Posted June 9, 2009 There are several things that can cause this... 1... Your front left brake is more worn than your front right, causing uneven braking power. This could be caused by a warped rotor that increased wear on the pads, a sticky caliper, or other minor things. Most of these things can be diagnosed and fixed easily without really spending any money when you're ready to do a brake job. It's really not that hard to do. I can get you diagrams and images if you want. 2... The front left caliper isn't getting any brake fluid when you step on the pedal. This could be caused by air in the brake lines from recent brake work or maintenance. Improperly bled brake lines could cause this also. Link to comment Share on other sites More sharing options...
