Japanparts Posted May 27, 2009 Share Posted May 27, 2009 it's all up to you, most people tend to go to a wider wheel when upgrading to aftermarket wheels since it allows them to increase tire width as well. otherwise at 17x7 you're still at stock size with nothing gained theoretically, aside from good looks but i can't blame you, the sti enkei wheels are a good looking wheel If you owned the STi Forester in Japan, you would likely order this with the STi wheels; there's only +pluses+ to having more rubber on the road as with a wider Wheel you can fit wider tires... GW Japanparts.com * Since 1996 * Link to comment Share on other sites More sharing options...
Japanparts Posted May 27, 2009 Share Posted May 27, 2009 Thanks Graham! These 17" ones will fit as well, right? Parts Manufacturer: STi Item No.: 1007G-060-W04 Price: 41,800 yen(JPY) / (497.42 CAD) Delivery time by air: 10-15 days Car Manufacturer: Subaru Car Name: Legacy BP/BL <Liberty> 2003/2004/2005, Legacy BP/BL <Liberty> 2006/2007, Legacy BP/BL <Liberty> 2008 JapanParts has these 17x7.5 5x100 55mm offset for $2000 CDN, $320 CDN Shipping SGP.com has the 17x7 5x100 48mm offset for $1500 CDN. As much as I'd like a wider tire, I can't see myself putting an extra $500 down to get 0.5" wider wheels.... I'll continue to check SubaruForester.org in the mean time.. Whaddyas think? Yes, fitment is 100% for Legacy + Forester models with 100PCD + 55mm of offset you are good-to-go... GW Link to comment Share on other sites More sharing options...
