2oo5Gt Posted May 18, 2009 Share Posted May 18, 2009 I have a cobb accessport and wanted to go stage 2 without getting there TBE. Would it be safe if i just installed an invidia or perrin DP with stock exhaust and run there map?? Link to comment Share on other sites More sharing options...
CasopoliS Posted May 18, 2009 Share Posted May 18, 2009 I have a cobb accessport and wanted to go stage 2 without getting there TBE. Would it be safe if i just installed an invidia or perrin DP with stock exhaust and run there map?? Should be safe. COBB recommends a TBE, and that is preferred, but not overly critical. Your best bet is to get a custom tune once everything is installed. Link to comment Share on other sites More sharing options...
Bolksey85 Posted May 18, 2009 Share Posted May 18, 2009 Should be safe. COBB recommends a TBE, and that is preferred, but not overly critical. Your best bet is to get a custom tune once everything is installed. :whore:Full turbo back is needed for most gain in power but not needed for a Stg2 flash. Good idea is to flash Cobb's OTS map, drive it and learn the power then when funds/time are available, get a pro tune. Link to comment Share on other sites More sharing options...
2oo5Gt Posted May 19, 2009 Author Share Posted May 19, 2009 thanks for the feed back fellas! Link to comment Share on other sites More sharing options...
BillyJoe Posted May 19, 2009 Share Posted May 19, 2009 i'm sure you already know this, but the Invidia downpipe has a flat-flange end that will have to mate with a donut-gasket connection on the Stock CBE. I'm running the same setup but i bought this a flange-to-donut adapter from rallysportdirect.com (made by eliteawd.com). Link to comment Share on other sites More sharing options...
2oo5Gt Posted May 19, 2009 Author Share Posted May 19, 2009 i'm sure you already know this, but the Invidia downpipe has a flat-flange end that will have to mate with a donut-gasket connection on the Stock CBE. I'm running the same setup but i bought this a flange-to-donut adapter from rallysportdirect.com (made by eliteawd.com). are you running the cobb stage 2 tune with this set up? Link to comment Share on other sites More sharing options...
ConeEluder Posted May 20, 2009 Share Posted May 20, 2009 i'm sure you already know this, but the Invidia downpipe has a flat-flange end that will have to mate with a donut-gasket connection on the Stock CBE. I'm running the same setup but i bought this a flange-to-donut adapter from rallysportdirect.com (made by eliteawd.com). I just bolted mine right up to the stock CBE, and so far no leaks. Link to comment Share on other sites More sharing options...
