littlerob904 Posted May 18, 2009 Share Posted May 18, 2009 I have an 08 Legacy 2.5i LTD I know theres been several threads related to this already, I combed them all and didn't really find any great ideas / opinions on what is necessary and what isn't. The dealer wants 540 bucks for the 30k and I'm thinking about just doing it all myself or having a mechanic (trusted) do a few of the tougher things. I'm somewhat handy, do my own oil changes, and I have access to any tools that I need (my roommate has everything) But I'm not sure of the difficulty involved for most of the services. Mainly the spark plugs and coolant flushes. How accessible are the plugs? I've helped do them on a dodge intrepid back in the day and it was a peice of cake, but I know some cars can be a nightmare just to get at them. Are the coolant flushes easy to handle? I have ramps and a decent sized drip tray that I use for oil changes. I was thinking of doing: Oil / Filter Coolant Flush Spark Plugs Rotate Tires Check Brakes and maybe having the mechanic do: ATF Flush Fuel Filter Replacement What do you guys think? Anything else I should include / disclude? The recommended guide included a bunch of bs inspections that they probably don't perform anyway. It also mentioned: Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil) Is this bs? or are there actual lubrications I should have completed? I'm a little weary about completing the coolant flushes as I've never done them before. Link to comment Share on other sites More sharing options...
littlerob904 Posted May 18, 2009 Author Share Posted May 18, 2009 This is the full list of the recommended 30k from my dealer: Inspect Drive belt(s) [Except camshaft] Inspect Camshaft drive belt Replace Engine oil Replace Engine oil filter Perform Replace engine coolant and inspect cooling system, hoses and connections Recommended Performance Replace fuel filter and inspect fuel system, hoses and connections Replace Air cleaner element Replace Spark plugs Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil) Inspect Automatic transmission fluid Replace Brake fluid Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions Inspect Brake linings and drums Perform Inspect brake lines and check operation of parking and service brake system Inspect Clutch operation Inspect Steering and suspension Perform Rotate and Inspect Tires Link to comment Share on other sites More sharing options...
blackfang Posted May 18, 2009 Share Posted May 18, 2009 This is what should be done for your 30k service Oil Change Rotate Tires Air filter Change Transmission fluid Change Coolant Change Brake fluid Adjust Parking brake. Fuel filter is non serviceable and if you really want to remove the fuel pump for that, by all means. Also the plugs are platinum and get changed at 60k, not 30k. $540 is a bit high for that service. I charge less than that for the same service above and I give you a tire balance w/ the rotation. Then again I had a customer who was quoted $1200 for her 30k for her Tribeca at another dealer, so anything is possible. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
littlerob904 Posted May 18, 2009 Author Share Posted May 18, 2009 This is what should be done for your 30k service Oil Change Rotate Tires Air filter Change Transmission fluid Change Coolant Change Brake fluid Adjust Parking brake. Fuel filter is non serviceable and if you really want to remove the fuel pump for that, by all means. Also the plugs are platinum and get changed at 60k, not 30k. $540 is a bit high for that service. I charge less than that for the same service above and I give you a tire balance w/ the rotation. Then again I had a customer who was quoted $1200 for her 30k for her Tribeca at another dealer, so anything is possible. $1200 wow! Thanks for the response, scrapping the plugs and fuel filter makes this a lot more do-able. I guess I'm going to go bust out my haynes manual and read up on the coolant flushes. Link to comment Share on other sites More sharing options...
HarryN Posted May 19, 2009 Share Posted May 19, 2009 Wow a service like that at my dealership would warrant me bending over, grabbing my ankles and squealing. Link to comment Share on other sites More sharing options...
Wang Lung Posted May 19, 2009 Share Posted May 19, 2009 I got quoted $439.00 at Maita Subaru in Sacramento. Link to comment Share on other sites More sharing options...
Rojo Posted May 19, 2009 Share Posted May 19, 2009 449 for the "basic", 600-700~ for the "gold" and 980~ for the "Platinum" at Subaru of Puyallup Link to comment Share on other sites More sharing options...
blackfang Posted May 19, 2009 Share Posted May 19, 2009 449 for the "basic", 600-700~ for the "gold" and 980~ for the "Platinum" at Subaru of Puyallup What is the difference? Honestly the 30k isn't that big of a service so there really should be no reason for it to be that much of a difference. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
dbrunone Posted May 20, 2009 Share Posted May 20, 2009 my 07 service manual says that the 2.5i spark plugs should be changed at 30k, while GT should be changed at 60k. I just got mine changed at 40k, because I'm stg2, and it was a waste of money. They could have gone 60k easy. Link to comment Share on other sites More sharing options...
blackfang Posted May 20, 2009 Share Posted May 20, 2009 my 07 service manual says that the 2.5i spark plugs should be changed at 30k, while GT should be changed at 60k. I just got mine changed at 40k, because I'm stg2, and it was a waste of money. They could have gone 60k easy. Yes it does. That manual is also the same one for all vehicles. However the 2.5i has platinum plugs like the GT which gets changed at 60k. Both can go longer than 30,000 miles. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
dbrunone Posted May 20, 2009 Share Posted May 20, 2009 Yes it does. That manual is also the same one for all vehicles. However the 2.5i has platinum plugs like the GT which gets changed at 60k. Both can go longer than 30,000 miles. GT plugs are Iridium. NGK SILFR6A. Maybe thats the difference. Link to comment Share on other sites More sharing options...
blackfang Posted May 20, 2009 Share Posted May 20, 2009 GT plugs are Iridium. NGK SILFR6A. Maybe thats the difference. Yes, but both do not need to be changed at 30k [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
littlerob904 Posted May 20, 2009 Author Share Posted May 20, 2009 What's the reasoning for changing brake fluid? I was under the impression that it's a closed system and should not need to be changed anywhere near 30k. Link to comment Share on other sites More sharing options...
blackfang Posted May 20, 2009 Share Posted May 20, 2009 Just because it is a closed system doesn't mean it stays clean. Just like any fluid it will get dirty over time especially when in a hydraulic system that can generate heat. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
Max Capacity Posted May 20, 2009 Share Posted May 20, 2009 Wow I do all this except the spark plugs. I paid my mechanic at the end of my street $120.00 to do that. Next time I may do them my self. I'll decide before Winter get's here. I'll have 112,000 miles by then. You should replace the fluids in the tranny and rear end. Oil changes are just something most people should be doing at a oil change place any way. All that inspect stuff any body with a good set of eye's can do. Most of it is pretty simple. Think about. If most people would just open the hood and look around, bend over look under the car you can see most everything. When you walk up to your car in a parking lot look it over and under as your walking up to it, look for spots in the ground, could be a leak. Just keep a record in small note book of everything you did and the date and mileage. Any thing you don't feel good about just have a trusted mechanic do. The stealer doesn't have to do this. The brake fluid thing is a good idea, may be. I'll bet most people never do that. Back in the mid 90's I asked a mechanic about it for my Civic. He said, that was the first he had heard of that. Ask the people you work with if they have there brake fluid changed. I haven't done mine yet in this car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mattg Posted May 20, 2009 Share Posted May 20, 2009 30k dealership service is for suckers Link to comment Share on other sites More sharing options...
blackfang Posted May 20, 2009 Share Posted May 20, 2009 30k dealership service is for suckers Then don't do it or have someone else do it. Apparently I see a lot of suckers then:lol:. Then again my prices are lower than most other dealers. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
mattg Posted May 20, 2009 Share Posted May 20, 2009 I didn't. Yeah, they're everywhere. Link to comment Share on other sites More sharing options...
OhBe1 Posted May 21, 2009 Share Posted May 21, 2009 How about checking for a reflash? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
blackfang Posted May 21, 2009 Share Posted May 21, 2009 Reflash for what? There has to be a particular concern that is noticed so they can see if there is an updated that may address that. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
NORULZleggy Posted May 28, 2009 Share Posted May 28, 2009 I just past 30k on my 08, and no i will not do anything till 60K. I inspected the belts and hoses my self, checked the fluids and changed the oil. Seeing how most of us on here are really into cars I Hope, I hope we could do and inspect most of this our selves. Link to comment Share on other sites More sharing options...
blackfang Posted May 29, 2009 Share Posted May 29, 2009 It is your car, you can do whatever you want. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
