08 Spec B stage 1 logs
LGTspecB1657615261
2008 Spec B MT
Bone stock - stock air filter
93 octane
63 degrees
Running mikeyd2005's 003 map here
950 miles on engine (still taking it easy at this point)
drove around for 5-10 minutes before logging in third, ecu is probably still learning at this point?
this log was the first time the car has ever been driven above 4.5k RPM. I was scared! Still taking it easy on the engine, staying under 4k RPM per the owner's manual (excepting this log of course). First oil change coming soon. Then, stage II. I have a LC-1 WB O2 which I will install in the new DP, so I can log AFR as well.
romraiderlog_20090517_155706.csv
LOL....at first I thought you had some factory freak that was as fast as cars with 20gs installed. Forgot you have a 6MT. Looks clean in the pull. Can you also do a 4th gear pull and log Mass airflow? Also check Learn Viewer to see if the car has any fine learned knock.
"Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T
