LGTspecB1657615261 Posted May 17, 2009 Share Posted May 17, 2009 So I am ready to flash Stage I - 2008 Spec B MT I have tactrix 2.0 and RR with all definitions setup. On the RR forums there is a Stage I base map, but MikeyD says to copy all the tables into your own ROM. I pulled the stock ROM off my ECU but copying all the tables will take forever! Why do you have to do this (rather than just flashing the file provided)? 1 - Is there a quick way to copy all tables from 1 rom to the other? 2 - Is there a list of the tables which are important to copy (I know not all of them are modified)? 3 - Is there an easier way to obtain an OTS STG I map? Thanks in advance. Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted May 17, 2009 Author Share Posted May 17, 2009 Just found out that you only need to copy tables if your car is a different year or tranny from the map... which was not an issue for me. I flashed the OTS map and Link to comment Share on other sites More sharing options...
