Zwever Posted May 15, 2009 Share Posted May 15, 2009 Hi, I am currently on Ohlins DFV, which comes with 7kg springs front and rear. Thinking of changing them to higher spring rate - anyone know what is the web address to purchase replacement ohlins springs? ohlins springs ID65mm, length 200mm Thanks Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted May 15, 2009 Share Posted May 15, 2009 You don't need to use "Ohlins" springs....they're just Eibachs painted yellow anyway. I'd recommend going with either Swift or Hyperco coilover springs....both are a little better than Eibach in my opinion. - Andrew Link to comment Share on other sites More sharing options...
NotMyGT Posted May 16, 2009 Share Posted May 16, 2009 You don't need to use "Ohlins" springs....they're just Eibachs painted yellow anyway. I'd recommend going with either Swift or Hyperco coilover springs....both are a little better than Eibach in my opinion. - Andrew Andrew is 100% correct. Although, Hyperco seems to have 2.5" springs and 65mm = 2.56" I doubt 6/100 will make a difference though. Swift does make a 65mm spring. Link to comment Share on other sites More sharing options...
Zwever Posted May 22, 2009 Author Share Posted May 22, 2009 thanks for your replies - I will check out SWIFT and Hyperco springs. Apparently CUSCO has 65/200mm springs too. Link to comment Share on other sites More sharing options...
