jimmy x Posted May 11, 2009 Share Posted May 11, 2009 Just installed my cusco rear sway bar with new cusco endlinks and a SPT Ver.1 CBE. Now I get this clanking sound in the rear. Sounds like the exhaust is hitting the sway bar. Any help would be great. Link to comment Share on other sites More sharing options...
whitetiger Posted May 11, 2009 Share Posted May 11, 2009 take a look under the car and the bar to exhaust clearance. you may have to put in aftermarket exhaust hangers to keep the exhaust ffrom moving around and hitting the bar. Link to comment Share on other sites More sharing options...
Th3Franz Posted May 11, 2009 Share Posted May 11, 2009 may want to consider some poly bushings too. The rubber ones the Cusco's came with allowed the bar to move around too much for me and cause clunking noises. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
scoobydoobie Posted May 11, 2009 Share Posted May 11, 2009 My rallitek RSB and kartboy endlinks have been clunking and popping around for me as well. I think I need to double check the endlinks. Link to comment Share on other sites More sharing options...
jimmy x Posted May 12, 2009 Author Share Posted May 12, 2009 I added rallitek hangers when I installed the upgrades. I took them off to re-adjust them and the clunk is still there. Can't figure it out. Link to comment Share on other sites More sharing options...
jimmy x Posted May 22, 2009 Author Share Posted May 22, 2009 Ok I finally figured out what happen with the sway bar. The cusco endlinks went bad or was bad to start with. The rubber linings wore out or something, there is a gap bettween the ball and the housing. Not sure why, but looks like Sh*T! But replace them with perrin ones. And now the sound is GONE! Link to comment Share on other sites More sharing options...
nemo Posted May 22, 2009 Share Posted May 22, 2009 hmm.... i just got the same sound today out of nowhere... after having my cusco's installed for a couple of months now. it's only coming from what seems like the front driver's side. local mechanic thinks it's the endlinks as well. looks like it's time to order some new ones. If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
TPLGT Posted July 16, 2009 Share Posted July 16, 2009 Anyone know if the KB Els are longer than stockers. I have clunking (with Cobb sways) Tech thinks that the stockers not providing enough clearence. replaced stock ELs but may upgrade to KB. Rehab is for quitters. Link to comment Share on other sites More sharing options...
LIZARD Posted July 17, 2009 Share Posted July 17, 2009 Ok I finally figured out what happen with the sway bar. The cusco endlinks went bad or was bad to start with. The rubber linings wore out or something, there is a gap bettween the ball and the housing. Not sure why, but looks like Sh*T! But replace them with perrin ones. And now the sound is GONE! Good luck with the Perrins, they'll hold for about 2 years. Mine did. Same exact scenario as with your Cusco ELs, the rubber linings went *poof*. Maybe I'll just buy them again and consider them "consumable-items";) and just replace em every 2 yrs. lizard Stage2.5376, TDC ProTune,blah blah blahhhh and....Alky/H20 injection Link to comment Share on other sites More sharing options...
LIZARD Posted July 17, 2009 Share Posted July 17, 2009 On another note jimmyx, are those cuscos adjustable? Stage2.5376, TDC ProTune,blah blah blahhhh and....Alky/H20 injection Link to comment Share on other sites More sharing options...
LIZARD Posted July 17, 2009 Share Posted July 17, 2009 Okay, I think I'm going with the Whitelines- FredBean's has them.. "Whiteline spherical bearing endlinks feature anodized aluminum turn-buckles and fully adjustable stainless steel rod-ends, allowing you to custom tune your suspension setup to maximize handling performance. Each Whiteline endlink kit for the Subaru Legacy GT includes a high tensile hardware replacements, rubberized dust boots for added bearing protection and easy to follow, application specific installation instructions; all features that many competitors cut to save time and production costs. Just one more reason why you can only expect the best in suspension performance from the experts at Whiteline. " Stage2.5376, TDC ProTune,blah blah blahhhh and....Alky/H20 injection Link to comment Share on other sites More sharing options...
Th3Franz Posted July 18, 2009 Share Posted July 18, 2009 I'm going to get whiteline links once my mod budget allows -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
jimmy x Posted July 19, 2009 Author Share Posted July 19, 2009 On another note jimmyx, are those cuscos adjustable? Yeah they are. The perrins are holding up so far. Link to comment Share on other sites More sharing options...
LIZARD Posted July 20, 2009 Share Posted July 20, 2009 Yeah they are. The perrins are holding up so far. Just ordered the Whitelines with the "booties" from ImportImage, great deal and they're on their way! Stockers will go back into "parts-chest" hibernation. Stage2.5376, TDC ProTune,blah blah blahhhh and....Alky/H20 injection Link to comment Share on other sites More sharing options...
