rurouni_x Posted May 2, 2009 Share Posted May 2, 2009 These tires just came out today and they are going to be the best non R-compound tire that you can get. The new king of extreme performance is here. I'm going to try to get a set of these for some auto-x and see how they do. The ADVAN Neova AD08 is Yokohama's Extreme Performance Summer tire developed for the drivers of sports cars, sports coupes and performance sedans that have a passion for sport driving. The ADVAN Neova AD08 is designed to provide high levels of traction, responsive handling and driving control on dry and wet roads, however it is not intended to be driven in near-freezing temperatures, through snow or on ice. The ADVAN Neova AD08 tread compound combines fine particle, Micro Silica (MS) with Hyper Density Carbon (HDC) to provide adhesion in damp and dry conditions. This compound is molded into a directional tread pattern that features twin circumferential center ribs and extra-wide Uniblock shoulders to increase cornering stability and steering response. Three large circumferential grooves and HydroArc Channels in the shoulders enhance wet traction. The tire's internal structure includes two wide steel belts reinforced by spirally wound nylon to provide strength and high-speed capability while the sidewalls are reinforced with steel cord inserts to resist lateral deflection and enhance control and cornering stability. Like the motorsports tires this Extreme Performance street tire has evolved from, the ADVAN Neova AD08 radial's construction and compounds have been tuned to maximize the tire's traction and performance within a specific range of ambient temperatures. Therefore, unlike less highly-tuned tires, Yokohama's care instructions specify that due to its compound characteristics, ADVAN Neova tires must be used and stored at temperatures above -10 degrees Celsius (14 degrees Fahrenheit) to maintain its performance and avoid tire damage. http://www.tirerack.com/images/trans.gifhttp://www.tirerack.com/images/tires/yokohama/yo_advan_neo_ad08_ci2_l.jpghttp://www.tirerack.com/images/tires/yokohama/yo_advan_neo_ad08_ci1_l.jpg http://www.tirerack.com/images/trans.gif Link to comment Share on other sites More sharing options...
katalyst Posted May 2, 2009 Share Posted May 2, 2009 wow, those are hot haha intersting...must store above 14F Link to comment Share on other sites More sharing options...
mightyS Posted May 2, 2009 Share Posted May 2, 2009 I just put on the AD07 three weeks ago. The description is the same except is says to keep the tires above 20 F. Link to comment Share on other sites More sharing options...
rurouni_x Posted May 2, 2009 Author Share Posted May 2, 2009 the 08's pown the 07's all around you should have waited Link to comment Share on other sites More sharing options...
Bolksey85 Posted May 2, 2009 Share Posted May 2, 2009 What's the wear rating on those bad boys? I'm assuming less than 200? Link to comment Share on other sites More sharing options...
VTGT Posted May 2, 2009 Share Posted May 2, 2009 ^+1 as well. Link to comment Share on other sites More sharing options...
Bolksey85 Posted May 3, 2009 Share Posted May 3, 2009 Well, the AD07's are rated at 180. The AD08's have a little more tread and it appears to be deeper but that means pretty much nothing. I guess they must be too new because Tire Rack has no real info on them either other than price and speed rating. Link to comment Share on other sites More sharing options...
Longitude Posted May 3, 2009 Share Posted May 3, 2009 Nice. Tread looks like brainz Link to comment Share on other sites More sharing options...
katalyst Posted May 3, 2009 Share Posted May 3, 2009 ^ you're right, now that i look at it again Link to comment Share on other sites More sharing options...
rurouni_x Posted May 3, 2009 Author Share Posted May 3, 2009 180 Link to comment Share on other sites More sharing options...
Basscadet Posted May 3, 2009 Share Posted May 3, 2009 Can't see putting tires like those on a LGT...maybe on an STi. Link to comment Share on other sites More sharing options...
mightyS Posted May 4, 2009 Share Posted May 4, 2009 Darn, I didn't know the AD08 were out. I'm still getting used to the difference between the AD07 and my old Re92s on the autocross course. I can hold 11 mph higher on the back sweaper on this course we use about once a month. Plus the sidewalls are stiffer and dont alllow the tire to roll over onto the sidewall like the Re92s did. Link to comment Share on other sites More sharing options...
VTGT Posted May 4, 2009 Share Posted May 4, 2009 They look expensive and good! Shouldn't you be autoxing your s2k not your lgt though Link to comment Share on other sites More sharing options...
AWDxBOOST Posted May 4, 2009 Share Posted May 4, 2009 cool beans...i wonder if its based off what they sell in japan Link to comment Share on other sites More sharing options...
rurouni_x Posted May 4, 2009 Author Share Posted May 4, 2009 They look expensive and good! Shouldn't you be autoxing your s2k not your lgt though I'm gonna try both Link to comment Share on other sites More sharing options...
RochNY91TSI Posted February 23, 2010 Share Posted February 23, 2010 How'd these tires do for you last year? I'm looking at them for a new set to replace my old Potenza S-03's Link to comment Share on other sites More sharing options...
