Deaks2 Posted April 24, 2009 Share Posted April 24, 2009 Last weekend I installed my Stage 2 hardware and flashed mickeyd2005's Stage 2 map (can be found here: http://www.romraider.com/forum/topic4468.html). I copied the relevant tables from the 2005 LGT map to my 06's ROM with SimpleTune (a nice little feature that RR should have...). The base map is running well, however, as usual, you can always get more power, smoothness, etc... especially since the base map was designed for Hawaii 92 octane. Here are the details: 2006 LGT 5MT OE paper filter BFG 50/50 BOV STI UP Invidia catless DP Canadian 94 octane E10 Here are my latest logs: 57 deg intake temp 14.65 psi atmospheric pressure IAM @ 1 Post logging LV: http://www.romraider.com/forum/download/file.php?id=8411 2nd gear to redline: http://www.romraider.com/forum/download/file.php?id=8403 3rd gear to redline: http://www.romraider.com/forum/download/file.php?id=8404 4th gear 2k to 3500: http://www.romraider.com/forum/download/file.php?id=8405 5th gear 2k to 3500: http://www.romraider.com/forum/download/file.php?id=8406 3rd gear 3000-4000: http://www.romraider.com/forum/download/file.php?id=8407 3rd gear 4000-5000: http://www.romraider.com/forum/download/file.php?id=8408 Driving around (big): http://www.romraider.com/forum/download/file.php?id=8409 mickeyd2005's last comments were: There's a tiny bit of loss in performance in 2nd gear. You will need a slightly smaller restrictor pill to improve boost response, but the benefit would be minimal. http://www.romraider.com/forum/download/file.php?id=8413&mode=view and; I looked through the big driving log. There was only one knock that did not appear to be noise. It was at time 338970. It was at 2750 rpm and 1.67 g/rev load. The AFR was really lean. It looks like tip in knock to me. It happens sometimes. I appreciate any input. Link to comment Share on other sites More sharing options...
Deaks2 Posted April 27, 2009 Author Share Posted April 27, 2009 Any help? Link to comment Share on other sites More sharing options...
