DarkOblivion000 Posted April 24, 2009 Share Posted April 24, 2009 Hey guys, I just got a brand new set of wheels (18" Kazera Kz-a's) and had them put on, but didn't have (and didn't remember I needed) the concentric rings. So I felt a lot of highway vibrations at 60+mph. Got the concentric rings yesterday, had them fitted and everything, rebalanced, and I STILL get vibrations at around 65-70mph. The weird thing is, it's not constant, its intermittent. So at 65-70, I'll get it, and then I'll speed up to 80, and it'll stop and then it'll come again, and then it'll feel fine for a while... I have NEVER bumped anything with the wheels, the tires are brand new as well, the car drives perfectly at under 60mph, WHAT COULD BE WRONG??? I'm taking the car into firestone again for them to drive it and see what could be wrong. Can't be an alignment either; I have never hit anything and the car is pretty new at 17k miles. There were absolutely no problems with stock rims. Any ideas?? Thanks in advance! :spin: Link to comment Share on other sites More sharing options...
GTTuner Posted April 24, 2009 Share Posted April 24, 2009 Same tires wre on the stock rims? Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted April 24, 2009 Author Share Posted April 24, 2009 No... stock rims had stock advan tires, new rims have brand new kumho's. Link to comment Share on other sites More sharing options...
GTTuner Posted April 24, 2009 Share Posted April 24, 2009 When a ride disturbance comes and goes like that it could be two or three things. 1. One or more of the tires has a "force variation" issue. Usually force variation is temp sensetive too (read, bad tire 2. On or more of the wheel/tire assemblies has excessive radial runout. 3. The balance is not correct. Generally when you get a ride disturbance you need to go to a place that has the Hunter Road Force balancer. It has a drum that it presses the tire against while spinning on the balancer to duplicate road force. Sometimes the wheel and tire can be optomized to reduce excessive road force. FYI, any tire wheel assembly above 15lbs of road force will cause a vibration in our cars. Link to comment Share on other sites More sharing options...
GTTuner Posted April 24, 2009 Share Posted April 24, 2009 Here is a little test you can do. Inflate the tires to 50psi. If the vibration goes away or is better it is a road force issue. Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted April 24, 2009 Author Share Posted April 24, 2009 Damnit, why does it have to be so complicated. No one else seems to have problems putting on new rims... So assuming the wheels are fine, and the tires are fine... I need a balance from a hunter road force balancer... Dealerships don't have problems balancing for cars not of their make right? (read: I can go into a Toyota dealership and get a balance?) 15lbs of road force... what does that mean? How would i measure road force? Link to comment Share on other sites More sharing options...
Dergara Posted April 24, 2009 Share Posted April 24, 2009 Take it to the dealer for an alignment. I have found they are the only ones that can get it right. I also think your tires are way out of balance. Get your money back after you take it to the dealer. “Abandon hope, all ye who enter here” -Dante Alighieri http://youtu.be/lLFunBPgPOo Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted April 24, 2009 Author Share Posted April 24, 2009 Here is a little test you can do. Inflate the tires to 50psi. If the vibration goes away or is better it is a road force issue. I will do that first thing Monday and see if it does or does not stop. Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted April 24, 2009 Author Share Posted April 24, 2009 Road force balancer runs $20 a pop x 4 = $80... Damn, that's not cheap yo. Link to comment Share on other sites More sharing options...
GTTuner Posted April 24, 2009 Share Posted April 24, 2009 Alignment isn't going to cause vibration. Road force can only be measured by a Hunter GSP9700 wheel balancer. Link to comment Share on other sites More sharing options...
GTTuner Posted April 24, 2009 Share Posted April 24, 2009 Road force balancer runs $20 a pop x 4 = $80... Damn, that's not cheap yo. The balancer costs $10,000. Thats why. What Kumhos are you running? Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted April 24, 2009 Author Share Posted April 24, 2009 Kumho Ecsta SPT's Also, I got the concentric rings from the guy that bought the wheels... but I'm not sure they are a correct fit... that would be the issue if they weren't right? I think he bought them for his GT, whereas I have a 2.5i. Would the ring sizes be the same for the two models? Link to comment Share on other sites More sharing options...
GTTuner Posted April 24, 2009 Share Posted April 24, 2009 Yes the would be the same. Those rings are usually plastic. The Kumhos I had (ASX's) were very good in terms of the uniformity of the tire. I just balanced them reqular and they were perfect. Link to comment Share on other sites More sharing options...
whitetiger Posted April 24, 2009 Share Posted April 24, 2009 sounds like you need to have the wheels balanced or you have a bent rim. Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted April 24, 2009 Author Share Posted April 24, 2009 hrmph... nothing wrong with the rim that I can see at all... Def just got them balanced and rings put in just this morning. Can't think of anything else except maybe the road force balancing bit... Link to comment Share on other sites More sharing options...
GTTuner Posted April 24, 2009 Share Posted April 24, 2009 OR, they could have water in the air lines and when they filled the tires they pumped some water in there. Had that happen to me once, drove me nuts!! That is usually a shake that will come and go at constant speed. Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 24, 2009 Share Posted April 24, 2009 Try hand torquing the lug nuts. Sometimes places will over tighten them with air tools. Link to comment Share on other sites More sharing options...
Dergara Posted April 24, 2009 Share Posted April 24, 2009 What about checking to see if they forgot to put any of the concentric rings in. “Abandon hope, all ye who enter here” -Dante Alighieri http://youtu.be/lLFunBPgPOo Link to comment Share on other sites More sharing options...
GTTuner Posted April 24, 2009 Share Posted April 24, 2009 What about checking to see if they forgot to put any of the concentric rings in. see post 15 Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted April 24, 2009 Author Share Posted April 24, 2009 OR, they could have water in the air lines and when they filled the tires they pumped some water in there. Had that happen to me once, drove me nuts!! That is usually a shake that will come and go at constant speed. Wow, never ever would have thought of that hahaha... unfortunately it's not a shake at constant speed... it's ONE speed range where it always happens, about 65-70mph. Try hand torquing the lug nuts. Sometimes places will over tighten them with air tools. Hmm, I will ask them about it... Well I'm just going to have the firestone guys take a ride with me and switch the front/back wheels, see if we can't isolate one wheel that's doing it. I figure I bought the lifetime balance from them so might as well use it to the max then if all else fails I can check out the road force bit... extra $80 I'm not really willing to spend... damn. Link to comment Share on other sites More sharing options...
Kylar Posted April 25, 2009 Share Posted April 25, 2009 I have seen tires cause a vibration because of a shifted or broken belt. Its not very common on new tires, but i have seen it happen before. Unfortunately if thats the case the only cure is replacing that tire Link to comment Share on other sites More sharing options...
DarkOblivion000 Posted April 27, 2009 Author Share Posted April 27, 2009 Resolved. Thanks for all the ideas guys!! There are definitely some issues here that I never would have thought of on my own. I went back and got it balanced again; as it turns out the first guy just did a sh*tty ass job balancing it... Sorry, now I feel like I wasted all your time, guys. Mai bahd. Anyway drives like a dream now! Link to comment Share on other sites More sharing options...
1badGtspecB Posted April 28, 2009 Share Posted April 28, 2009 check tires for bumps.....i have the same problem but I know mine is because my tire has those air bumps on them...I no I no its dangerous to drive on them... Link to comment Share on other sites More sharing options...
vkchu Posted April 29, 2009 Share Posted April 29, 2009 about those 'bumps' / bulges-is it possible that only one sidewall of the tire can get it? i usually hand inspect my tires after hitting a pothole, but if its on the inside facing the brakes, i wont be able to tell. so does a bulge mean its happened on both sides or no? Link to comment Share on other sites More sharing options...
LongHiway Posted April 29, 2009 Share Posted April 29, 2009 I'll offer another one. When they put the wheels on, they over-tourqued the lug nuts and you have a warped rotor (hopefully) or now have a warped wheel hub. Link to comment Share on other sites More sharing options...
