tingtang Posted April 12, 2009 Share Posted April 12, 2009 I just had someone install the innovate lc-1 wideband o2 and for some reason it looks like I'm reading extremely rich... at throttle it sits at 10.2.... when I roll off the throttle it drops to 7.6.... if I remember correctly shouldn't u read lean when off the throttle?? I'm thinking they didn't calibrate the WBo2 correctly?? I know my car is running rich... but 10.2 is pretty rich... I'm on 91 oct pump gas.... ill try to re-calibrate the sensor today... but if anyone has suggestions or anything that would be great... thanks... Link to comment Share on other sites More sharing options...
boostsr20 Posted April 12, 2009 Share Posted April 12, 2009 Should be in the 14:1 range at idle and 11:1 at WOT. Link to comment Share on other sites More sharing options...
tingtang Posted April 13, 2009 Author Share Posted April 13, 2009 ^ at idle I'm at the same wot... at idle it sits at 9-10 it jumps around but at any throttle in boost it stays at 10.2... then when I roll off the throttle it sits at 7.6.... I know the car was tuned to run rich... but 10.2 is really rich... I dunno Link to comment Share on other sites More sharing options...
tommypenguin Posted April 13, 2009 Share Posted April 13, 2009 Try doing a Free Air Calibration and then log your front o2 sensor, I believe the parameter in romraider is called 'A/F sensor 1' or something like that, and compare it to your wideband afr, if your wideband is calibrated right it will read fairly comparable numbers to that sensor. Link to comment Share on other sites More sharing options...
tingtang Posted April 13, 2009 Author Share Posted April 13, 2009 I can log my front wideband?? ill try that tomorrow... its really weird though.... my wideband doesn't go below 7.4 and doesn't go above 10.2 ever.... thanks for the suggestion nick ill try that and let u know what happened... any suggestions on how I should calibrate the wideband?? Link to comment Share on other sites More sharing options...
caramall2 Posted April 13, 2009 Share Posted April 13, 2009 +1...calibrate and check against stock sensor when you're in low load/low boost; for AFRs 14 and up the LC-1 values and the stock sensor (AF Sensor 1 in RR) should be aprx the same. Read the LC-1 pdf on how to install and do a free air calibration...it's on their website if you need it. Link to comment Share on other sites More sharing options...
Legend Posted April 13, 2009 Share Posted April 13, 2009 Is your LC-1 programed for gas (14.7:1)? My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
tommypenguin Posted April 13, 2009 Share Posted April 13, 2009 Haha, I bet you it isn't, since his never reads higher than 10.2. You should connect your wideband to the Logworks and make sure you're fuel is set up for pump gas and not e85 also as legend suggested. Link to comment Share on other sites More sharing options...
tingtang Posted April 13, 2009 Author Share Posted April 13, 2009 I haven't hooked it up to my laptop yet... I just had it installed and they told me they calibrated it... I bet that's it... ill try all that tomorrow... thanks all of u guys for me bein a noob I thought it was a little weird no matter how much I floored it I couldn't get it to read over 10.2..... hahaha.... Link to comment Share on other sites More sharing options...
