****I got KNOCK****
FASTONE
Hi, i have been tuned by a local tuner and now just wanted to make sure that i m running ok, and looks like that i got knock, here is a attached image of learning view, never used it and not sure what the numbers mean exactly but usually -4 is not good. so here is the image, i logged it using RR and it only does it during hard shifts. http://i395.photobucket.com/albums/pp39/timkl25/LearningView_SS_4-10-200984725PM.jpg
Here are the two quick logs http://www.box.net/shared/o0qgk4ta0t
and http://www.box.net/shared/a89f2ubiti
2nd is the one with shift and knock. ****PLEASE advice what to do, i will do a few more logs and post tomorrow****
Did more logs, everything looks ok>
Here: http://www.box.net/shared/tj320v7r4n
and
http://www.box.net/shared/derdvuabci
i ve done more pulls and no knock, can someone chipe in and explain how come learing view shows the negative numbers??
Fast shifting almost NEVER causes FLKC. The ecu keeps track of the moving average of the change in load per unit time. If load is changing quickly, it will choose to use FBKC instead of FLKC when it detects knock.
The car has problems. Either the tune or mechanical. Take a look at AFR Learning A&B.
If you have a leak near the front O2 sensor (lower gasket of uppipe, or any of the exhaust manifold gaskets), it will cause the AFR Learning A and B to become very large positive. It usually doesn't cause problems except higher fuel consumption and more emissions and slightly slower boost response.
You should get a WBO2 and check your AFRs.
whats a WBO2, i have a leak at from DP to cat back, will fix it this week, can it cause that, i check the uppipe and turbo connectors with soap and water. Do i have a problem and possibly issue with a motor.turbo or just something to keep in mind
Are you sure your airbox is sealed right, that the locking tabs aren't off or anything?
I'm scaling my stock intake with perrin drop in filter right now, but my AFR learning A and B weren't nearly as high as yours even when I was using the stock scaling.
