Regal05LGT Posted April 10, 2009 Share Posted April 10, 2009 I just put some wheels on (work emotion cr kai 18x7.5 +42) and I am rubbing the fender over big bumps...not all the time....I need an alignment because I just swapped in h techs to get some more clearance for the wheels. What degree of camber should solve this? Are the stock bolts enough or should I get other bolts? Thanks! Link to comment Share on other sites More sharing options...
trackhore Posted April 10, 2009 Share Posted April 10, 2009 front or rear? Can't give you a number as it all depends on your unique set-up: wheel size, offset, tire height, tire width, ride height. There is no camber adjustment in the rear, and I was able to get as much as -1.5* up front with stock adjustments and Ion springs. Link to comment Share on other sites More sharing options...
Regal05LGT Posted April 10, 2009 Author Share Posted April 10, 2009 Sorry lol, the fronts are rubbing.....I am thinking about just doing a slight fender roll and just not worry about it anymore. I thought the stock bolt only gives you +/- 1 degree? Does it vary from car to car? Link to comment Share on other sites More sharing options...
Th3Franz Posted April 11, 2009 Share Posted April 11, 2009 some camber bolts can get you around -1.5 degrees. the offset on your wheels is low and that's causing the issue I think. Some more camber and rolling your fenders should do it if you don't want to part with those wheels. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
MDork Posted April 11, 2009 Share Posted April 11, 2009 im gonna guess he won't want to part with the wheels Link to comment Share on other sites More sharing options...
robinlsb Posted April 11, 2009 Share Posted April 11, 2009 Jeepers, do an alignment first, then decide:) "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Regal05LGT Posted April 11, 2009 Author Share Posted April 11, 2009 im gonna guess he won't want to part with the wheels Good call I am prob going for an alignment soon...get as much as I can off the stock bolt, and try to find someone to roll my fenders....anybody local wanna make some money??? Link to comment Share on other sites More sharing options...
