radzio Posted March 24, 2009 Share Posted March 24, 2009 Hello everyone, Recently I noticed that when i put the key into ignition and turn it to start the car it does not do anything, after trying for few times it finally clicks and starts the engine. The battery is fine, the lights do come on after turning the key, the starter would be cranky noise before going dead, could it be that the ignition system/resistor is going dead? Link to comment Share on other sites More sharing options...
foolds Posted March 24, 2009 Share Posted March 24, 2009 Is this a manual or auto. I would guess this is the Starter solenoid. How old is the starter? how old is the car? Link to comment Share on other sites More sharing options...
radzio Posted March 24, 2009 Author Share Posted March 24, 2009 It's 5spd manual. 1995 legacy brighton. 225,000 km on it. Link to comment Share on other sites More sharing options...
987687 Posted March 24, 2009 Share Posted March 24, 2009 When you turn the key and it doesn't start, do you hear relays clicking? At least you have a 5MT, just get in the habit of parking on a hill to pop start it Link to comment Share on other sites More sharing options...
Bdubs Posted March 25, 2009 Share Posted March 25, 2009 Clean all grounds, and the terminals on the battery and on the starter. My car would do this when the temperature would change from warm to cold quickly, or when it was damp. Don't go replacing the starter right away, the rebuilt ones are pieces of shit, and you'll be replacing it again in another 10k miles. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted March 29, 2009 Share Posted March 29, 2009 I've had similar problems with other vehicles. It could be a dead spot on the starter or a starter relay. If you hear a click when you turn the key it's the starter (Probably a dead spot). If you don't hear a click it could be either the starter relay or the solenoid, but proably not the solenoid. It was easier for me to check my relay on the vehicle with the relay issue, because it was a diesel pickup. All I did was pull the relay and use a piece of wire to make the connection manually. When the connection was made the engine turned over. It's not going to be as easy on your car... Link to comment Share on other sites More sharing options...
