doubts about turbo cut in
hi any bros out there, could any kind soul explain the below?
understand that for lgt, the turbo starts to cut in when we ram rpm above 2.5k
now if we accelerate constantly and say we achived 120km/h and now rpm is above 2.5k
does the turbo cuts in in this case?
kindly advice
Are you talking about boost? Boost is determined more by pedal position then rpms. You can drive at 3k on the freeway and you can run 20 hg of vacuum(negative boost). But when you get on the pedal the waste gate closes and you build boost.
Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com
It's determined by both. Under a certain RPM value (~2.5-3K RPM), it doesn't matter if you floor the car as there won't be enough exhaust flow to build boost in the turbo. Above that, it's determined by throttle position (oversimplified).
I think smallsmall needs to read up here.
http://auto.howstuffworks.com/turbo.htm
The whole turbo not boosting below a certain RPM is called lag. When it "cuts in" is usually refered to as when it "starts to boost". This will usually be a certain RPM, at wide open throttle. Speed doesn't play into it a whole lot.
Smallsmall, to better understand lag and boost, go find an empty backroad, and stick it in 3rd, and slow down to about 1000-1500 rpm... then floor it, and hold it till you are at a staisfactory speed. Strictly speeking that's not good for the car, you should never drive below 2000 rpm under any sort of load, but it will be a good demonstration of turbo lag.
You 2.5 guy's should try that in a 2L with a VF39. Doesn't get to full boost till 4K, but boy does it kick you in the back when it does boost :D
Turbo response is directly related to engine load. More load, more heat. More heat, quicker spool.
Watch a boost gauge. Floor it in 2nd at 2000RPM and note when you hit peak boost. Now floor it in 3rd at 2000RPM and note when you hit peak boost. This point is countered slightly by surge. Surge is when you attempt to flow more air than the turbo is actually capable of flowing at a given pressure ratio. Meaning that the engine is sucking air through the turbo at a rate higher than the exhaust powering the turbo would be capable of allowing. It's called surge (and it's different than compressor surge). I haven't seen a compressor map for the stock turbo, but I doubt surge is much of an issue and the above comparison should hold mostly true.
It's actually quite a bit more complicated than that, but for the most part it can be generalized that turbo response can be directly related to engine loading and not engine RPM.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
You are all so wrong! The Turbo is normally off until you flip the regulator switch under the tachometer which then sends a signal to the odometer which then calls the nearest subaru dealership to confirm turbo activation, once activated the turbo then begins building boost at rate of 3psi per engine stroke depending on the altitude of the car. But that is only in the spec B series of the legacy. Pootling.
So, where does the VTEC sticker play in all this. I hear it gets you at least 10 to the wheels:lol:
Only to the front wheels. VTEC stickers are bad for your center diff.
  • 5 weeks later...
