Deunan Posted March 21, 2009 Share Posted March 21, 2009 Hi, would 2004 sti stock brembo system fit 2008 OBXT??? front and rear??? Thanks Link to comment Share on other sites More sharing options...
mwiener2 Posted March 22, 2009 Share Posted March 22, 2009 fronts are a direct bolt on rears need a mounting bracket rears also need a special rotor if you like the functionality of your parking brake My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
magnetic1 Posted March 22, 2009 Share Posted March 22, 2009 That is correct^ We also have the Wilwood alternative. LGT sized rotors up front w/ upgraded calipers. Pads, rotors, etc are also a ton cheaper than STi stuff. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Deunan Posted April 27, 2009 Author Share Posted April 27, 2009 Forgot to ask, would stock bolt do? or need aftermarket bolt needed to upgrade to 04 STI brembo. So what parts I need from 04 STI Brembo? Caliper 2 Rotors 2 bolts and nuts? or stock would do? Thanks. Link to comment Share on other sites More sharing options...
LowFast Posted April 27, 2009 Share Posted April 27, 2009 +1 for the Wilwood set-up, just got mine on this weekend and I am loving it! Link to comment Share on other sites More sharing options...
PhilT Posted April 27, 2009 Share Posted April 27, 2009 Forgot to ask, would stock bolt do? or need aftermarket bolt needed to upgrade to 04 STI brembo. So what parts I need from 04 STI Brembo? Caliper 2 Rotors 2 bolts and nuts? or stock would do? Thanks. The thread size on the Brembos is different than the stock bolts, so you will need new bolts. You also need the adapter brackets on the rears, and of course larger wheels to clear them. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
