Heat Posted March 19, 2009 Share Posted March 19, 2009 I have a 2009 LGT with 13k miles. Recently, after having the car in for some warranty work regarding the radio/antenna. Today I drove a few hundred miles. Afterwards I noticed it was difficult to turn the steering wheel. I thought maybe I had just became used to the sloppy forester steering. I just checked the power steering fluid level. It was at the very lowest line, "cold min". I assume that it is simply low on power steering fluid. I suppose it's a little strange that I noticed this right after the car was repaired. My plan is to just add some power steering fluid. I find it a bit odd that it's low already, given that it is so new. Any thoughts/suggestions? Thanks in advance guys. Link to comment Share on other sites More sharing options...
StupidDent Posted March 19, 2009 Share Posted March 19, 2009 don't think they would touch that area... did you notice any leak? i would just bring it back and let them know since it's still under warranty. good luck! Link to comment Share on other sites More sharing options...
c-lo Posted March 19, 2009 Share Posted March 19, 2009 yeah, radio is to the right, and steering wheel to the left. can't see why they'd touch unless you have s.w. controls and were having issues with that too 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
