RustyShackleford Posted March 18, 2009 Share Posted March 18, 2009 I built this simple mount for attaching my Sirius radio to my cubby. First, I found a scrap piece of aluminum lying around, about 1/16" thick. I shaped the end to fit snugly into the cubby, up against the side wall closer to the driver. Then I bent it. Then I drilled 4 holes in the AMPS-style pattern used by Sirius radios. Then I painmted it black, first using a special primer (you can't just paint aluminum directly). The fit was snug enough to hold my Stratus 4 (very light). But I used some velcro to hold it against the side of the cubby. Or you could glue it. The mount is removable, still allows access to the cubby (for holding knick-knacks), and is free (if you have basic tools and an appropriate metal scrap lying around). I still need to use some sort of cable tie to neaten up the wires ... Link to comment Share on other sites More sharing options...
nka Posted March 18, 2009 Share Posted March 18, 2009 well done, usefull.... but not very cute ! Link to comment Share on other sites More sharing options...
RustyShackleford Posted March 18, 2009 Author Share Posted March 18, 2009 well done, usefull.... but not very cute ! Speak for yourself ! I think it is, except for all the stray wires - I need a plan for those. Link to comment Share on other sites More sharing options...
nka Posted March 19, 2009 Share Posted March 19, 2009 Didn't want to be rude... I'm not the kind of guys who think cute, so it's perfect for me. I would prefer to have a rally car dash with all options than a cute OEM with less options. but well... resell value Link to comment Share on other sites More sharing options...
