robert Posted March 10, 2009 Share Posted March 10, 2009 So i wanted to flush my tranny now that ive installed tranny cooler. Called the only dealership left in my area and they wanted $350. Anyone figure out a way to DIY, drain and fill? Link to comment Share on other sites More sharing options...
robert Posted March 10, 2009 Author Share Posted March 10, 2009 If i drain and fill, how many quarts will come out of the drain plug? Will i be able to drain at least half the fluids? Link to comment Share on other sites More sharing options...
pierce88 Posted March 10, 2009 Share Posted March 10, 2009 you can drain 5 quarts out of the total 16. My local dealer wanted $250. $90 for labor plus the cost of of the fluid. Link to comment Share on other sites More sharing options...
fishbone Posted March 10, 2009 Share Posted March 10, 2009 No way the tranny takes 16 quarts. It's either 9.6 or 10. I think you pay for 16 quarts because that's how much the flushing machine needs for a flush. Draining it you replace about 4.5 - 5 quarts. If you ask me, you're probably better off doing 3 drains back to back. Do a drain, drive it a few miles, repeat. My dealer wanted $130 IIRC. Link to comment Share on other sites More sharing options...
botbs Posted March 10, 2009 Share Posted March 10, 2009 you can drain 5 quarts out of the total 16. My local dealer wanted $250. $90 for labor plus the cost of of the fluid. That's expensive $8 here x 5 quarts + tax + shipping = ~$50 http://www.fredbeansparts.com/servlet/the-1379/Subaru-Automatic-Transmission-Fluid/Detail $50 bux if you could do it yourself or $100 if your treat your mechanic friend a dinner Link to comment Share on other sites More sharing options...
subie_dude05 Posted March 10, 2009 Share Posted March 10, 2009 No way the tranny takes 16 quarts. It's either 9.6 or 10. I think you pay for 16 quarts because that's how much the flushing machine needs for a flush. Draining it you replace about 4.5 - 5 quarts. If you ask me, you're probably better off doing 3 drains back to back. Do a drain, drive it a few miles, repeat. My dealer wanted $130 IIRC. 4EAT takes 10. that how i flushed mine, 4 qts at a time. drain 4 and drive and then drain 4 and drive and drain 4 and drive. then drain 4 and replace it every 50k or so. Link to comment Share on other sites More sharing options...
AKLGT Posted March 10, 2009 Share Posted March 10, 2009 I flushed and changed my LGT every 15K miles. but i also tracked the car. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
robert Posted March 11, 2009 Author Share Posted March 11, 2009 Ive got 5 quarts due to arrive tomorrow from fred beans along with some exhaust gaskets. I still cant beleive the dealer wants $350?!? WTF... Looks like i will do the drain and fill. Link to comment Share on other sites More sharing options...
fishbone Posted March 11, 2009 Share Posted March 11, 2009 AKLGT, your avatar reminds me of these pics of mine. http://legacygt.com/forums/showthread.php?t=91087 No idea why. Link to comment Share on other sites More sharing options...
mtnbiker3000 Posted December 7, 2011 Share Posted December 7, 2011 OK, so I have been reading so many posts my head is starting to spin... On my 2008 2.5i AT (30K), I am swapping the diff fluids (going to try the WalMart Super Tech on both) and also bought 4 quarts of the Soobi ATF HP. My question is, is it even beneficial to drain and refill just 4 quarts in the AT? Or should I just wait till about 60K and do a more complete fluid exchange to get the whole 10 quarts swapped out? And, if I do just go with a drain and fill, can I get the same net effect by simply draining from the drain plug as pulling off the entire pan? Really don't want to pull the pan unless it's a superior method... Also, I was talking to my Tech, and he stated (as well as stated in the manual) that the external AT filter is a 'maintenance free' filter and really never needs to be changed unless showing rust or other damage. Thoughts?? Thanks!!!!! Link to comment Share on other sites More sharing options...
doctorbrody Posted December 8, 2011 Share Posted December 8, 2011 On an Impreza 2.5i 4AT, I got 9 quarts to come out of the transmission. Actually had to go back to the store to get more fluid since I don't have that much on hand. I parked the car so the trans drain plug was pitched slightly downhill and it all poured out. Changed that car from factory fluid to Mobil 1 ATF. On my OBXT 5EAT I can only get about five qts out at once. I use Amsoil universal synthetic ATF and just do the five qts every 25-30k miles. I change the filter every other ATF change. No transmission problems at 130k miles, lots of torque and an IPT VB mod. Link to comment Share on other sites More sharing options...
hardball75006 Posted December 9, 2011 Share Posted December 9, 2011 I still cant beleive the dealer wants $350?!? WTF... No doubt! I wonder if the $350 includes hookers and beer? Link to comment Share on other sites More sharing options...
2.5GT_dude Posted December 9, 2011 Share Posted December 9, 2011 Do it yourself and save money From a thread of mine: I also wouldn't do a power flush. I would do one of two things: 1)Do a drain and fill, drive ~500 miles, repeat, repeat. This will use around 10 quarts and will effectively replace around 2/3 of your original fluid. 2)Disconnect the trans cooler output line and feed into a bucket. Start car and allow 3-4 quarts to drain into bucket, then shut off and replace same amount with fresh fluid into the dipstick. Repeat this until 100% has been exchanged and is clean. This will essentially "flush" your trans without using the power flush that the horror stories come from. This method has been advocated by climberD, 5eat chief guru... Link to comment Share on other sites More sharing options...
mtnbiker3000 Posted December 9, 2011 Share Posted December 9, 2011 Thanks GT dude... I might try running the old fluid out of the tranny through an output line, if I can easily locate it? Any ideas on it's location a 2008 2.5i 4EAT?? Also, what are your thoughts on changing the external filter?? Thanks!!! Link to comment Share on other sites More sharing options...
doctorbrody Posted December 9, 2011 Share Posted December 9, 2011 I change the external filter every 60k miles. Just because Subaru says it's maintenance free doesn't make it so. Oil filters have a finite lifespan and they're not that expensive to replace. Also, removing the filter will get more ATF out of the system. Link to comment Share on other sites More sharing options...
mtnbiker3000 Posted December 9, 2011 Share Posted December 9, 2011 Yeah, I'll probably wait till 60k for the filter. Heard they're hard to get off though Link to comment Share on other sites More sharing options...
mtnbiker3000 Posted December 9, 2011 Share Posted December 9, 2011 Just reading through the manual, and it states to 'air bleed the control valve' when draining and refilling the tranny. For this you need the Subaru Select Monitor. Per the manual: When ATF is drained from the automatic transmission, make sure to bleed air from the control valve after filling with the specified amount of ATF. Perform the procedures according to the message displayed on the Subaru Select Monitor. What is the deal with this bleeding process?? Dealership? Skip it? Thanks Link to comment Share on other sites More sharing options...
doctorbrody Posted December 9, 2011 Share Posted December 9, 2011 Never bled any air from either the 4AT or the 5EAT, never had any problems. Filter is a minor pain on the turbo cars, easy on the 2.5i. Link to comment Share on other sites More sharing options...
