JDM HID with Leveling Switch Walkthrough
Bumping this old thread. I just received pair of JDM HID lights and now need to figure out how to flip the shields and convert the wiring, both for main harnesss and levelling harness. This thread talks mainly about the leveling motor harness, any info on the main harness conenctors type? I'd like to do a clean install and fabricate harness for both sides.
2005 LGT Wagon Limited 6 MT RBP Stage 2 - 249K
2007 B9 Tribeca Limited DGM - 272K
  • 7 months later...
  • Replies 63
JDM OEM HID converts, do you run your JDM harness straight from USDM headlight harness or do you use additional harness with separate relay? Comparing USDM and JDM wiring I see that both OEM are in fact relayed and should be a straight plug in with proper connectors. DRL is unplugged to I am not worried about that at this point.
  • 2 years later...
Great write up.. Where can I find the pigtail connector to the leveling switch. I've looked everywhere and on japanparts. They only show the replacement leveling switch. Edited by MarcLgtSTI
I believe I found the pigtail connector. It is a toyota part...go figure. You also need the repair wires. I believe I found the correct pins if you want make your own for much less money.
Connector: Toyota 90980-10797
Repair Wires: Toyota 82998-12340
Pins: Sumitomo Conn-11-856 (ballenger motorsports)
I haven't tested it yet as I don't have my jdm lights or a leveling switch. This was found by searching over the past day.
Edited by rhino6303
I gambled on the connector and it's too large. Unfortunately it's still a no go. I've spent hours searching through toyota wiring pdfs as they actually give connectors and part numbers but nothing looks close enough. The newer brz/frs has hids and a leveling switch but the connector is different.
  • 4 weeks later...
I found the actual manufacturer of the leveling switch connector in the dash and have the part number but I cannot find any source for the connector. I sent an email to the manufacturer to see about sourcing the connectors but I doubt I'll hear back.
Furukawa Caselanceless Compact Connector 8 position/pin female unsealed connector.
Connector part number CC08F-W PK365-08018
Pins part number MT395-05090
Edited by rhino6303
Clarity. Leveling switch connector on dash
I thought it was sumimoto and it is sealed connector. I spent a lot of time trying to identify main connector and zeroed in on Sumimoto. You can download their connector catalog online, but there are many different series of connectors, hard to find exact match based on pictures.
But main problem is that even if part number is known getting it is whole other story. some are available on alibaba from China, but most are bulk quantities, same as from single us source. Jim from Eastern beaver was most helpful but he doesn't have these connectors either.
My JDM hids came with connectors so I am all set. I believe our 07 Tribeca has same connector for headlights. try some junk yards in your area.
I'm talking about the switch for the leveling connector on the dash. The leveling motor does use the sumitomo sealed. I'll edit my post to be more clear.
My bad, I jumped to respond without going back in the thread. I believe but not 100 % certain that that connector is same type as door mirror connectors. It's been a while since I checked. but usdm legacies have 8 position connector on GT/OBXT (heated/adjustable and with turn signal), 6 on non turbo (no turn signal ).
JDM folding mirrors will have 12 pole connector. (I should check what I posted in folding mirrors thread).
If I get some time today I will try to verify what I just said, should have extra mirror and switch laying around.
Edited by SubOperator
Corrected info on pin numbers
My bad, I jumped to respond without going back in the thread. I believe but not 100 % certain that that connector is same type as door mirror connectors. It's been a while since I checked. but usdm legacies only have up to 6 position connector on GT/OBXT (heated/adjustable and with turn signal), 4 on non turbo (no turn signal ).
JDM folding mirrors will have 8 pole connector.
That would be great. If you can, take a picture of the connector from the front. Thanks.
It is the same EXACT connector actually. USDM GT mirror connector is 8 pin and plugs right in dash HID leveling switch. I will upload pictures later today.
Awesome! I was researching wiring diagrams after you mentioned the mirror and saw the connector on the usdm heated/turn mirrors to be the same shape connector in the fsm. I was just getting ready to take apart my door panel to check, haha. Thanks for saving me from doing so!
Edit: This is also the same connector from a base model 2008-2010 Impreza/WRX with non-heated mirrors.
Edited by rhino6303
Glad this helps you, thanks for info on base Imprezas, should be easier to find connectors.
Here are the pics, in no particular order, but as you can see mirror connector is exactly the same and I tested plugging it in the actual leveling switch.
http://legacygt.com/forums/attachment.php?attachmentid=248521&stc=1&d=1493601386
http://legacygt.com/forums/attachment.php?attachmentid=248522&stc=1&d=1493601386
http://legacygt.com/forums/attachment.php?attachmentid=248523&stc=1&d=1493601386
http://legacygt.com/forums/attachment.php?attachmentid=248524&stc=1&d=1493601386
http://legacygt.com/forums/attachment.php?attachmentid=248525&stc=1&d=1493601386
http://legacygt.com/forums/attachment.php?attachmentid=248526&stc=1&d=1493601386
http://legacygt.com/forums/attachment.php?attachmentid=248527&stc=1&d=1493601386
No, thank you for letting me know about the mirrors! I have spent so much time finding the correct connector as I want a clean install. Now to just find somone with a destroyed mirror...
  • 10 months later...
tldr - Im interested if anyone has done a proper pinout/breakdown of thejdm bl/p plugs at the leveler switch. Its hard to get an idea of how the pin positions in the plugs are suppose to get wired.
Viewed from rear/pin side, left to right I have-
pin 1- purple
pin 2- black/white
pin 3- blank
next row
pin 4- green/yellow
pin 5- green/red
pin 6- red/green
pin 7- black
pin 8- blank
From the scattered informative posts Ive read I understand 2 wires are for illumination, 2 wires are for ignition power and ground, and two are outputs to the 3 pin plugs on each headlight for signal (1 wire to each headlight)
So can anyone rattle off the information to make the approproate connection?
Btw I can confirm its is the same plug for the leveler switch as the oem usdm mirror plugs male side of course.:confused:
  • 7 months later...
I know it’s an old thread and I did a search but it seems most people are to lazy to open up the housings, how many of you have done the shield flip as well as hooking up the switch leveler?
  • 1 year later...
I've done the shield flip and am about to undertake the leveler.
I'm not very familiar with electrical so I need to ask: is it ok to splice the ignition power, ground, and parking lights into the remote mirror control harness? If so, do I just match the wires, i.e. purple to purple, black to black, green/yellow to green/yellow?
Thanks in advance.
muFreight.co
A JDM Container Sharing Service from Japan 🇯🇵 to NYC 🗽
 🌐 Website📷 Instagram✉️ Email
Bessie II's Thread
Thanks in advance.
That should be fine. how's the harness working out for you?
I'd like to buy one if you have any available ^ (this is leveling motor connector right?). The headlight harness is working great - I just did a track day on Monday 3.5 hours away in upstate New York. No flickering in either direction - thanks man.
muFreight.co
Bessie II's Thread
Glad they are treating you well. I’m just waiting for a couple friends to install and let me know if I need to make adjustments. You already have the motor connector on your kit. This is from the switch in cab to the headlight.
Hi. I'm trying to understand wich parts will I need yo make the conversion. My car it's a 2005 European 3.0R Spec B Sedan. The harness you fabricate it's plug and play? I will order the HID healights. Which parts will I need more?
Edited by K_Senhor
In addition to the leveling motor AW4BYT will hopefully start selling soon, he also make a harness for the JDM high-beam/low-beam/turn signal (https://legacygt.com/forums/showthread.php/jdm-usdm-headlight-harness-bl-bp-283236.html). That is what you need unless you want to do the wiring yourself. I would send him a PM to see if he can make more. I am very happy with mine. It's very high quality (heat shrink, abrasion resistant sleeving, Deutsch connectors, etc.), I couldn't have made something better myself.
muFreight.co
Bessie II's Thread
