br7sv9x8 Posted February 24, 2005 Share Posted February 24, 2005 i need help how come my rear tail light is not on but then when i signal it lights up. i didnt the fog light mod but im not sure its that. but if it is, is there anyway i can have the fog mod on and still have the rear tail lights on instead off. help plz thanks you -br7sv9x8 Link to comment Share on other sites More sharing options...
myUsername Posted February 24, 2005 Share Posted February 24, 2005 Do you use the hazard lights when checking the signal lights? Is your key on the on position when switching on the head/parking lights? Have you tried the little switch on top of the steering wheel? Link to comment Share on other sites More sharing options...
mwiener2 Posted February 24, 2005 Share Posted February 24, 2005 br7sv9x8 Are you talking about the red Brake and tail lights, or the orange/amber turn signal/hazard lights? btw, did you make that name up by smashing keyboard or does it stand for something? moved to exterior My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
GTSpeed Posted February 24, 2005 Share Posted February 24, 2005 Smashing the keyboard....LOL...That was rich! Link to comment Share on other sites More sharing options...
br7sv9x8 Posted February 24, 2005 Author Share Posted February 24, 2005 it stand for some. im talking about the top lights in the back were its red the top part. not the bottom part for the 2 rear tail lights its doesnt glow but then it flashes when i signal do you thing it can be the mod that made it like that the one beep to unlock the door mod? if thats the case then i just rewire the lock thing then. thanks for the comments guys -br7sv9x8 Link to comment Share on other sites More sharing options...
Opie Posted February 24, 2005 Share Posted February 24, 2005 That's the way it is supposed to work... Bottom bulb is parking and brake lights, upper bulb is turn signals. Link to comment Share on other sites More sharing options...
Alex1 Posted February 25, 2005 Share Posted February 25, 2005 uh not trying to be mean or tactful.. but i really cant understand much of that Link to comment Share on other sites More sharing options...
mwiener2 Posted February 25, 2005 Share Posted February 25, 2005 yeah me either, i've totaly lost you now My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
SBT Posted February 25, 2005 Share Posted February 25, 2005 Hi, We're not sure from your post whether you're talking about the turn-signal light or the rear tail lamp. Here's what I think you mean. When you turn on the hazard/flasher switch, the turn signal light in the rear works but the rear tail lamp does not. If this is what you mean, then that is normal operation. There's only three times that the rear tail lights will light up. 1) The ignition switch is turned on to "Run" and the light switch is either in the parking light or headlight "on" position 2) The ignition switch is turned on to "Run", the light switch is either in the parking light or headlight "on" position and you step on the brake pedal. Then the brake lamps light and the rear tail lamps are on 3) The ignition switch is turned "off" and the small rocker switch on top of the steering column is turned to the on position, then the rear tail lamps will be lit. Did this help to clarify? If you followed the fog light mod correctly, then the fog lights should come on when the key is turned to the "run" position and the parking lamp switch is in the "on" position. Your rear tail lamps (not turn signal lamps) should also be lit at this time. If the rears are not on with the key on and the headlight switch in the park or on position, then something is wrong. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
br7sv9x8 Posted February 25, 2005 Author Share Posted February 25, 2005 yes that sound much better thank you very much for clearing that up for me. and sorry about not making it clearfor you guys, thanks -br7sv9x8 Link to comment Share on other sites More sharing options...
X-RAY Posted February 27, 2005 Share Posted February 27, 2005 Just got back from the car wash,turn the car off and the parking light stayed on. Went to the manual and found on page 20 parking light switch. With the tint on the windows it was hard to see.Life is good.. Link to comment Share on other sites More sharing options...
