Subie Boy Posted February 24, 2009 Share Posted February 24, 2009 Has anyone done this before? As in change the clock trip to where the ashtray is? I just bought the kit from Jap Parts and wondering if someone can show me pics of theirs and tell me how to do it. Thanks heaps. Link to comment Share on other sites More sharing options...
Subie Boy Posted February 24, 2009 Author Share Posted February 24, 2009 BUMP....anyone?? Link to comment Share on other sites More sharing options...
Abandonhope16 Posted February 24, 2009 Share Posted February 24, 2009 Try a search, I thought I remember a walkthrough being posted for this; there are several that have done it. Link to comment Share on other sites More sharing options...
arkadyzv Posted February 24, 2009 Share Posted February 24, 2009 I have one, you have to trim the attachment tabs on the relocation kit itself because the info panel hits them before it mates. Since the unit is made to tilt to the driver and we sit on the opposite side. Mine is just hot glued in place, so far so good for the last 3 months. Link to comment Share on other sites More sharing options...
wagonmaster87 Posted February 24, 2009 Share Posted February 24, 2009 What's the point of this mod? Is it just so you can put a Double Din headunit or navigation in there? Link to comment Share on other sites More sharing options...
arkadyzv Posted February 24, 2009 Share Posted February 24, 2009 Yes, frees up the top , thus you are able to put a double DIN up top. I have my 7" touchscreen there for the car pc. Not to mention it looks really nice sitting down there. Link to comment Share on other sites More sharing options...
wagonmaster87 Posted February 24, 2009 Share Posted February 24, 2009 Gotcha. Yeah I have a 7" touch flip screen in the cubby, its only a one din unit so I didn't have to move my info panel. Link to comment Share on other sites More sharing options...
Subie Boy Posted February 25, 2009 Author Share Posted February 25, 2009 Yes, frees up the top , thus you are able to put a double DIN up top. I have my 7" touchscreen there for the car pc. Not to mention it looks really nice sitting down there. Thanks for the info man, are you able to send me some pics? Either PM me or through this thread? It would be much appreciaterd Link to comment Share on other sites More sharing options...
NSFW Posted February 25, 2009 Share Posted February 25, 2009 http://www.legacygt.com/forums/showpost.php?p=1992851&postcount=2 Sorry, no pics from behind. Here's the process in a nutshell: Lift the trim panel around the shift level by pulling up on it. I'm assuming you have an MT car. I have no idea about AT cars. Unscrew the shift knob. Lift off the knob, boot, and trim panel as a single piece. Remove the trim on either side of the shifter & radio by removing the two screws (one per side) aft of the shift lever, then pull back (toward the rear of the car) on each. Remove the radio by pulling the screws on either side (2 are deep in there, the rest are easily visible). Unhook the radio wiring - just feel around back there, you'll find little tabs under each connector, just squeeze and wiggle and pull. To get the stock bezel out, put a screwdriver (or butter-knife, whatever) in the seam on the bottom and pry outward. Sounds awful but it works pretty well. At this point you have everything apart. It's pretty easy to see how it all goes back together. You might have to get creative to get the relocated info panel attached to where the ash tray was - in the USDMs, the mounting screws don't line up quite right. But I put the screws in at funny angles and it's held for about a year now. Link to comment Share on other sites More sharing options...
Subie Boy Posted February 25, 2009 Author Share Posted February 25, 2009 thats awesome, what an inspiration....thanks heaps, mate! Link to comment Share on other sites More sharing options...
f1anatic Posted February 25, 2009 Share Posted February 25, 2009 You guys are hilarious. You are telling the guy to trim the piece to make it fit since the kit was designed for RHD cars...but none of you major-domos looked at where the user is from: Sidney, Australia. For him, the part will fit without problems - or rather without OUR misalignment problems. Everything they said holds right up, espec. NSFW. In addition use any, some or all of the attached materials. They will teach you some or all the steps needed to remove the parts you need and run the kit.26 - Air Vent Grill.pdfradio-install-A.pdfradio-install-B.pdfradio-install-C.pdf Link to comment Share on other sites More sharing options...
Subie Boy Posted February 26, 2009 Author Share Posted February 26, 2009 Thanks heaps for all the info, guys! Link to comment Share on other sites More sharing options...
Subie Boy Posted March 2, 2009 Author Share Posted March 2, 2009 Got my parts today, will post some pics when done and installed! Link to comment Share on other sites More sharing options...
