Unreal Posted February 13, 2009 Share Posted February 13, 2009 I got a cobb catted downpipe on the way. Once I get it installed the car is going over to the cobb dyno to get protuned. Right now my 2007 spec B is completely stock besides HIDs. Are there any other mods I should do before shelling out the money for tuning that are reasonable and easy? I really really want to stay with the stock mufflers/etc because I am going to put a hitch on the car to pull my motorcycles around. Would stuff like a midpipe and TMIC be worth the cash? The car is a daily driver just looking for a bit more pep. It will never be tracked or raced. Link to comment Share on other sites More sharing options...
Spec B Posted February 13, 2009 Share Posted February 13, 2009 With the DP you will be at a basic Stage 2, you could get an aftermarket mid and Y pipe to use with the stock mufflers, but that would not give you much HP overall. The TMIC will give you some slight gains, but the more important roll of the aftermarket TMIC is the piece of mind that it will stay intact (the stock IC has been known to have the endtanks come loose and leak at stage 2 boost levels). IMO, based on your goals, I would skip the dyno tune and just run the basic Stage 2 cobb map (or get an opensource E tune from infamous1 or some other tuner). good luck! Link to comment Share on other sites More sharing options...
Unreal Posted February 13, 2009 Author Share Posted February 13, 2009 I'm getting it protuned on the dyno using opensource for just a few bucks more then that. Link to comment Share on other sites More sharing options...
black318i Posted February 13, 2009 Share Posted February 13, 2009 I'd get an upgrade IC. After a few weeks at 17 psi mine showed sign that it may fail soon even after using epoxy on the tabs. After I installed my Perrin TMIC I had to tweak my timing. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted February 13, 2009 Share Posted February 13, 2009 I'd get upgrade the IC. Link to comment Share on other sites More sharing options...
fonts Posted February 14, 2009 Share Posted February 14, 2009 +2 on the TMIC. Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted February 14, 2009 Share Posted February 14, 2009 +3 for upgrading the intercooler. Most likely a used Perrin TMIC forsale on the fourm right now for a good price. Link to comment Share on other sites More sharing options...
