nasiocks Posted February 4, 2009 Share Posted February 4, 2009 For the last couple of weeks I started noticing a whining noise from the transmission. I only notice it when pushing the shifter to the right as if I was going into 5th. And of course it does it when I have it in 5th. I don't seem to notice it right away. Or at least it's more noticeable when the car has warmed up. 05 LGT just accessport stage 1. I have had a Kartboy short throw shifter and front shifter bushings for a couple of years now so it's not from those. 54k on the clock, and I had the trans and diff service done by the dealer around 35k. And I never launch my car. Bad syncro(s)? Link to comment Share on other sites More sharing options...
Impulse Posted February 4, 2009 Share Posted February 4, 2009 oh, another rochester person on here? i had something like this this spring/summer. is the noise ONLY while you're engaged in 5th? or does it happen when you cruise on the highway in neutral? it turned out to be a bad rear-transfer case bearing or something like that and they had to remove the transmission to fix it. Link to comment Share on other sites More sharing options...
nasiocks Posted February 4, 2009 Author Share Posted February 4, 2009 It only does it when it's in 5th gear or if I push the stick to the right as if I was going to go into 5th. It doesn't have to be engaged in 5th to make the noise. Even when I'm stopped and I push the stick to the right I can hear it a little bit. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2009 Share Posted February 4, 2009 Have the dealer look at it. You have until 60,000 miles then it's on you. May be get a second opinion from a local tranny shop. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
