valleylegacy Posted February 2, 2009 Share Posted February 2, 2009 I just recently put in the Rallitek 22mm front sway bar with rallitek HD front end links. I am experiencing some clunk/banging noise during slow speed turning ... as if Im turning to park the car in a spot or sometimes moving in a parking garage turning left or right. Any advise to what I may have done wrong is greatly appreciated. Link to comment Share on other sites More sharing options...
wcbjr Posted May 7, 2010 Share Posted May 7, 2010 I am getting the same thing. To top it off, one of my wheel studs is 1/2 stripped. Nothing can go right for me at the moment. 22mm FSB with lock collars and HD endlinks. Happens over small bumps especially. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted May 8, 2010 Share Posted May 8, 2010 I'm getting the same noise.. Its seems like these posts are created all of the time but I can't find any conclusions. Both of my end links are still in one piece and look fine. The sway bar feels tight when I moved it with my hand. I can not recreate the noise when I'm under the car, only when I am driving and hit bumps / speed bumps in the road. This is getting really frustrating. Link to comment Share on other sites More sharing options...
Mungo Posted May 9, 2010 Share Posted May 9, 2010 Most seem to fix their problem by tightening their endlink bolts. Make sure you use the 5 mm allen key in concert with a crescent wrench. Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted May 9, 2010 Share Posted May 9, 2010 Today I took off my end links and sway bar mounts, cleaned and greased everything, and tightened it all back up.... Still getting the noise... I checked all of the bolts on the wheels, steering rack, and the subframe and they are all tight. I also made sure that the sway bar was not hitting anything either. I have come down to two conclusions: bad lower control arm bushing or bad strut. I am leaning towards a bad strut since they're stock with 58,000 miles on them and Rallitek lowering springs. Any other ideas? Link to comment Share on other sites More sharing options...
wcbjr Posted May 10, 2010 Share Posted May 10, 2010 Tonight I tried to tighten everything down further. I might have gotten another 1/16 rotation on the sway bar brackets and one bolt on an endlink got another 1/4 rotation. No more clunks. Apparently that small of a change can make a difference. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
