dvdt Posted January 25, 2009 Share Posted January 25, 2009 I have a clunk from the passenger side front when I turn the steering wheel. I believe I've found the problem... http://i17.photobucket.com/albums/b71/dv2dt2/DSCF5172.jpg http://i17.photobucket.com/albums/b71/dv2dt2/DSCF5173.jpg Should I just replace w/ OEM or is there something better? My suspension setup is just Swifts/Konis/JDM RSB/stock FSB. Link to comment Share on other sites More sharing options...
PeterJMC Posted January 25, 2009 Share Posted January 25, 2009 You can replace them with Whiteline bushings. Link to comment Share on other sites More sharing options...
Regal05LGT Posted January 25, 2009 Share Posted January 25, 2009 Something clunks when I turn the wheel too.... I have koni/swift as well, I gotta get under the car n check it out, just been too cold Link to comment Share on other sites More sharing options...
ilh Posted January 25, 2009 Share Posted January 25, 2009 Mine have looked like that 40K+ miles, and my steering doesn't clunk at all. Link to comment Share on other sites More sharing options...
Regal05LGT Posted January 25, 2009 Share Posted January 25, 2009 I wonder what my issue is then..... could the LCA bushings cause a clunking sound? Link to comment Share on other sites More sharing options...
PeterJMC Posted January 25, 2009 Share Posted January 25, 2009 I had a clunk on the passenger side front only after lowering and installing sways, did both at the same time. After a few months I fixed it... this was my problem http://legacygt.com/forums/showpost.php?p=1465116&postcount=11 Link to comment Share on other sites More sharing options...
dvdt Posted January 25, 2009 Author Share Posted January 25, 2009 hmm.. interesting, thanks for the info. But I've had my swifts on for over 40K and my Konis in for maybe 10K. The clunk is a very recent development and its really light (I can only hear it driving really slow/parking). I'm going to replace the bushings and see if it helps. Link to comment Share on other sites More sharing options...
Regal05LGT Posted January 25, 2009 Share Posted January 25, 2009 I was thinking that the spring was maybe not seated in the perch/top hat 100%....... prob gonna pull em out n check once the warm weather arrives Link to comment Share on other sites More sharing options...
