Diggs753 Posted January 29, 2009 Share Posted January 29, 2009 Thanks guys...I really don't want to get anything to aggressive on this.I was hoping to stay around 235/45-50/18 area not much more...I have no interest in trying to get the biggest size possible.I want something that doesn't stick out too far,maybe a little more than stock but not much, and still has a compliant ride for DD. I really like the look of PFF's,SSR five spokes,06 SpecB and 3.0R rims.But I don't want rim that has a special size that will limit tire availibility. I wish there was an OB only pics post of wheels and tires. Link to comment Share on other sites More sharing options...
fredrik_wt Posted March 12, 2009 Author Share Posted March 12, 2009 ok, I have now order rims but not tires, the rims is a steelgray Rota GRA 18"x7.5" offset 48, 245/45 tires will not be any problem, no rubbing?? I was thinking about that the rota rims got same offset as stock rim and tires will be much wider.?? Link to comment Share on other sites More sharing options...
Diggs753 Posted March 12, 2009 Share Posted March 12, 2009 pics when installed please Link to comment Share on other sites More sharing options...
EvergreenOutbackXT Posted June 24, 2009 Share Posted June 24, 2009 Does anyone have a set of stock 05-06 outback XT rims they want to get rid of? Link to comment Share on other sites More sharing options...
Bimmer Posted June 28, 2009 Share Posted June 28, 2009 If you are talking 18" wheels, then 235/50 is slightly taller than stock, about a 1/2". I would think you would be ok running that tire. A 225/50 is 1/4" taller than stock and that would be good for sure. This would be pushing it... There's so little space around the tires in the wheel wells that Subaru says not to use snow chains. Try this: Turn the front wheels all the way to one side, and then jack up each of the rear corners of the car (so you get a rear wheel up), and look at how much space you've got between the tire and the fender liner. I bet it's less than 1/2". Bimmer Link to comment Share on other sites More sharing options...
Yon, L3.0R 08 Posted November 21, 2009 Share Posted November 21, 2009 Is it possible to add wider tires than the stock ones? like this ones (for a 2008 legacy sedan) and keeping the 17' rim size (wider rim also of course) http://www.6gunracing.com/images/javidMain.jpg Link to comment Share on other sites More sharing options...
nastyhello Posted December 16, 2009 Share Posted December 16, 2009 will these tires fit for the winter on stock LGT wheels? 245/45R17 Link to comment Share on other sites More sharing options...
