How wide rims, and what tires is possible?
Posted
I have just bought a "new" outback, 2008. I want to know who low ET that is possible to go with, and how wide the rim can be.
Is 8" maximum or can I go with 8,5" with ET45? is ET 40 possible?
Posted
I have 245/45/18 tires on 8.5" wide rims. +48 offset. The back rubbed a very little bit on the INNER fender, so I trimmed the plastic a bit and I was fine.
So if you can find some 8.5" with a +45 to +40 offset you are gold running 245 tires.
:icon_twis Slide It Sideways :icon_twis
Posted
If you are talking 18" wheels, then 235/50 is slightly taller than stock, about a 1/2". I would think you would be ok running that tire. A 225/50 is 1/4" taller than stock and that would be good for sure.
Now if you are talking 17" wheels, a 235/50 is about a 1/2" shorter than stock. Don't do 225/50 on a 17....it will be too small and look funny IMO, but you can do it. If you are sticking to 17" wheels, the 245/50/17 size is a VERY close size to stock.
Posted
ok, but I want to go with 235/50, 50 is still ok?
Do you already have those tires? Is that why you want to use that size?
As mentioned above, 245/45 is the preferred size for a 18" diameter on an Outback.
The 235/50 is 1/4" bigger in diameter overall and that could be a problem.
Posted
19X8 ET 40 with 225/45/19.
When the steering wheel is turned all the way, the front tires will touch the plastic liner behind the front fog lamps but I can live with that.
http://img60.imageshack.us/img60/669/44586136kf7.jpg
http://img368.imageshack.us/img368/9195/28977234gp2.jpg
Posted
*cough* ahem please don't roast me here, but I'm a outback noob so:
I put my 2005 LGT wheels from my old 2000 impreza, on my 2005 outback limited. So what tires should I pick up instead of these tiny 215/45/r17's. How big should I go, what brands are good, and how much should I expect to spend. I'm not planning on lowering it so keep that in mind with your advice....Cuz this look just has to go, I'm not feeling the tiny tires at all.....
Before:
http://i47.photobucket.com/albums/f170/Carolynsoccer/snowwagon.jpg
After:
http://i47.photobucket.com/albums/f170/Carolynsoccer/IMGP3590.jpg
http://i47.photobucket.com/albums/f170/Carolynsoccer/IMGP3589.jpg
Posted
I should have read this before my post but, what brands are good and how much?
Posted
After:
LGT wheel has 55mm offset, Outback wheels has 48mm offset, so the LGT wheels and tires on an Outback will look "tucked in" :)
You may purchase wheel spacers to push the wheels outwards if you know what you are doing.
Posted
With stock 17" Legacy rims, you should probably just run the stock 17" Outback size: 225/55R17
Posted
Well if you plan on keeping those LGT rims, I would say get the stock size tire. 225/55/17.
Posted
I was looking into a set of 06 SpecB rims and a set of Prodrive p1 18" w/53 offset for a 07 OBXT w/stock suspension.Anyone have a set up similar?And will I need spacers or rings to makes this work?
thanks
Posted
thanks
It will bolt right on, but the + 53mm offset means the wheel will look "tug-in" unless the wheel is at least 7.5 inch wide to compensate for the 5mm of space lost due to the offset difference.
If you have an 8 inch wide wheel it will be better.
17x7 +55mm offset
19x8 +40mm offset
http://img377.imageshack.us/img377/5563/87018309ps0.jpg
An 8 inch wide wheel with +40 offset will push the outside lip of the wheel out 27.7mm or around 1.1 inch when compared to a 7inch wide wheel at +55mm offset.
Posted
Yeah, don't be too scared of a lower offset wheel. You can go down to +45 no sweat and even down to +40 on an Outback.
Remember that Outback stock offset is +48
Posted
Yeah they are 7.5..and they have 5mm spacer that might be included in the deal...http://legacygt.com/forums/showthread.php?t=100381
Posted
FWIW, our 235/55/17's on stock rims, come close at full lock, but do not rub.
06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest.
