zarak Posted January 12, 2009 Share Posted January 12, 2009 I just got a 2009 Legacy GT. It's manual, and there is a little green shift arrow that comes on when the car thinks I should shift. It is kind of annoying, so I would like to disable it. Does anyone know how to do this? Link to comment Share on other sites More sharing options...
Crawdaddy79 Posted January 12, 2009 Share Posted January 12, 2009 Put the car in Sport mode, and leave it there. Link to comment Share on other sites More sharing options...
Cannonball Posted January 12, 2009 Share Posted January 12, 2009 Take it out of "I" mode. Sorry you beat me to it. Link to comment Share on other sites More sharing options...
zarak Posted January 12, 2009 Author Share Posted January 12, 2009 Thanks. Guess I would have realized that after break in. I've been staying mostly in I for the first 1000 miles to take it easy on the car. Link to comment Share on other sites More sharing options...
gf2020 Posted January 13, 2009 Share Posted January 13, 2009 Thanks. Guess I would have realized that if I had read the owner's manual. Fixed it for you. Link to comment Share on other sites More sharing options...
zmarko Posted January 13, 2009 Share Posted January 13, 2009 Thanks. Guess I would have realized that after break in. I've been staying mostly in I for the first 1000 miles to take it easy on the car. For the record, the car won't go into S# mode until it's warmed up a bit. Link to comment Share on other sites More sharing options...
zarak Posted January 14, 2009 Author Share Posted January 14, 2009 You would think reading the owners manual would have done it as well, but I first did what I thought was one step better. I asked the dealer when I had it in to get the accessories installed. They said they had no way to turn it off. Maybe THEY should read the manual too! Link to comment Share on other sites More sharing options...
stingray1967 Posted January 14, 2009 Share Posted January 14, 2009 Black electrical tape over that part of a gauge cluster? Link to comment Share on other sites More sharing options...
bradlgt21 Posted January 14, 2009 Share Posted January 14, 2009 I didn't know the new LGT's had that. I learned stick on a ford focus and it had the same thing. Annoying as hell and it wanted you to shift way to early. I would go into the next gear at like 15000, rpm and the car would shake. Even driving stick for the first time I could tell that was to low of a RPM. Link to comment Share on other sites More sharing options...
Bbc84 Posted January 14, 2009 Share Posted January 14, 2009 yea i think the green arrow comes on a bit too early on the higher gears. there is no way imma shift into the next gear and make the car shake, even though the green arrow tells me. Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted January 14, 2009 Share Posted January 14, 2009 Does any one else think thats the turn signal when it comes on. It always gets me. Link to comment Share on other sites More sharing options...
lordeldor Posted January 14, 2009 Share Posted January 14, 2009 I didn't know the new LGT's had that. I learned stick on a ford focus and it had the same thing. Annoying as hell and it wanted you to shift way to early. I would go into the next gear at like 15000, rpm and the car would shake. Even driving stick for the first time I could tell that was to low of a RPM. That was one hell of a focus you had. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 14, 2009 Share Posted January 14, 2009 That was one hell of a focus you had. And that was too *low* of an RPM! Link to comment Share on other sites More sharing options...
Knight705 Posted January 14, 2009 Share Posted January 14, 2009 it must of had a special edition jet turbine engine in it... hahaha Link to comment Share on other sites More sharing options...
Backlash Posted January 14, 2009 Share Posted January 14, 2009 yea i think the green arrow comes on a bit too early on the higher gears. there is no way imma shift into the next gear and make the car shake, even though the green arrow tells me. it's all about fuel economy. the green arrow takes liberties with the situation, it's programmed for flat ground, and hardly any acceleration once you shift. does not take anything into consideration, speed limit is 45 you are at 25... it's all "perfect world" scenario crap. thus, fairly worthless to follow. annoying, but it's not the first time i've driven a car with the "feature" so i'm used to it. Link to comment Share on other sites More sharing options...
Sunra Posted January 15, 2009 Share Posted January 15, 2009 Anyone know how to turn off the GPS screen in an '09 Spec B? I know I can use the dial on the dash to turn down the illumination, but that dims the dash too. It seems to be on all the time, either stuck at the initial 'agreement' screen or displaying GPS or monitor stuff. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 15, 2009 Share Posted January 15, 2009 Try the turning 'Guidance Screen' off under the nav setup menu. I don't know if it'll stay off indefinitely, but I know I've turned it off before. Edit: Ignore that ^. kenzo's instructions below are correct. Link to comment Share on other sites More sharing options...
kenzo Posted January 15, 2009 Share Posted January 15, 2009 Right-most (real) button and then the "OFF" (onscreen) button. This works in my '08 - I keep the screen off most of the time. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 15, 2009 Share Posted January 15, 2009 Right-most (real) button and then the "OFF" (onscreen) button. This works in my '08 - I keep the screen off most of the time. I'd keep it off too, but then I'd lose the clock. They should've done a boost/oil temp/water temp/oil pressure gauge instead of those useless fuel/acceleration gauges. Link to comment Share on other sites More sharing options...
kenzo Posted January 15, 2009 Share Posted January 15, 2009 I'd keep it off too, but then I'd lose the clock. They should've done a boost/oil temp/water temp/oil pressure gauge instead of those useless fuel/acceleration gauges. Clock is available in the dash "info display"... Totally agree on the pointless virtual gauges - especially the gas pedal position ("Hey! I wonder how much I'm pushing the gas pedal!") Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 16, 2009 Share Posted January 16, 2009 Clock is available in the dash "info display"... Totally agree on the pointless virtual gauges - especially the gas pedal position ("Hey! I wonder how much I'm pushing the gas pedal!") Hmm. Hadn't thought of that. If the screen stays off after a restart, I might start doing that. Link to comment Share on other sites More sharing options...
