AZZMAN Posted January 3, 2009 Share Posted January 3, 2009 Hey sounds like I need new pads for my 06 specB 36k miles. I have a friend that work at a local garage and will do my brakes for free but I need to get the brake pads. He thinks rotors are ok... no noise no shake under brake pressure. Any place other than my Subaru parts dept where I can get new pads? Maybe some better pads than Subaru can offer... I don't want to spend much my fourth kid is on its way in Feb! Link to comment Share on other sites More sharing options...
fonts Posted January 3, 2009 Share Posted January 3, 2009 Contact Jeremy from King of Parts. I'm running Hawk HPS pads and am very happy with them. Seems that a lot of other members are also happy based on feedback in other posts. Good luck. Link to comment Share on other sites More sharing options...
RaGe Posted January 3, 2009 Share Posted January 3, 2009 +1 for jeremy at thekingofparts ( http://www.5-starperformance.com/servlet/the-913/Hawk-HPS-Subaru-Legacy/Detail ) and +2 for HAWK HPS. see above link. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
AZZMAN Posted January 4, 2009 Author Share Posted January 4, 2009 I went to the above link and noticed a stage II brake upgrade. I'm at stage II and thought this might be a nice upgrade... My winter wheels are smaller than the stock summer tires. Right now the wheel just clears the brake pads. Does anyone know if the stage two has bigger thicker pads rotors or both? Link to comment Share on other sites More sharing options...
fonts Posted January 4, 2009 Share Posted January 4, 2009 Better quality rotors and pads. Similar setup to what I bought from Jeremy at KOP (DBA-4000 rotors and Hawk HPS pads, SS lines and fluid). Very happy with the results. Shouldn't be an issue with wheels. You'll typically have problems with rotors fitting under the wheels. The problem isn't with the pads or rotors .... unless you have the wrong ones. Link to comment Share on other sites More sharing options...
f1anatic Posted January 4, 2009 Share Posted January 4, 2009 Contact Vimy101 - a member here on the boards. He can teach you all you want about Spec B and he is local to you. Link to comment Share on other sites More sharing options...
trackhore Posted January 4, 2009 Share Posted January 4, 2009 Stage2 brake upgrade uses OEM sized rotors, and as already mentioned, pads don't affect wheel fitment. I recommend HPS pads for street use. Nice upgrade over stock, low noise, acceptable dust levels, which from my experience, has been less than the OEM pad. Link to comment Share on other sites More sharing options...
