Madjik_Man Posted February 9, 2009 Share Posted February 9, 2009 Update: the dealer couldn't find any problems. Still been driving fine. Hopefully it was just a rock and has since dislodged. that happens to my Tacoma now and then. a rock/pebble literally gets up onto the wheel and spins around making squealing and/or grinding noise (picture a rock spinning around on you metal wheel)... and it happened to me on my way to up the local ski resorts in Winter too when there's a lot of gravel on the road. when you checked under your car did you look for rock(s) on your wheels? the first time it happened to me it damn near made me sh*t my pants... the noise is wretched Link to comment Share on other sites More sharing options...
tdoggydog Posted February 10, 2009 Author Share Posted February 10, 2009 Does the issue go away if the vehicle is parked and idling or parked and turned off? If it goes away because you are turning the vehicle off, then I'd definately look for a loose heat shield. The heat shield may only be rattling once warmed up and perhaps it takes a particular bump in the road/turn of the wheel/etc to get the noise started. Yes, it does tend to go away when either in reverse or when the car is turned off and settles briefly. Link to comment Share on other sites More sharing options...
tdoggydog Posted February 10, 2009 Author Share Posted February 10, 2009 So it sounds like the problem may be random with pebbles and whatnot, or could be a loose heat shield. I'm no mechanic - can someone describe to me where the heat shield is located, what it may come in contact with, etc.? That way, if you think I can coach the dealer on what to look for, their diagnosis/fix can be more targeted. Thanks, guy! I really appreciate it! Link to comment Share on other sites More sharing options...
BlackPearl07 Posted February 10, 2009 Share Posted February 10, 2009 This sounds like a problem I have as well. Mine comes from the driver's side front wheel, I think. It eventually goes away only to return. The car drives fine and will stop on a dime. It is frustrating to not know if something is wrong or not. I'm going to take mine into the dealer since its still under warranty. Link to comment Share on other sites More sharing options...
tdoggydog Posted February 10, 2009 Author Share Posted February 10, 2009 I'm glad this is not just my car - maybe between all of us affected we can help the dealers figure out what the problem is and how to fix it. Link to comment Share on other sites More sharing options...
tdoggydog Posted February 12, 2009 Author Share Posted February 12, 2009 I posted over on Nasioc and they feel the same way that it's most likely just grit in the wheels/brakes and nothing to worry about. My question now is, as I prepare to head up the mountain again, do I just keep driving if it happens or should I pull over as soon as possible? Link to comment Share on other sites More sharing options...
tdoggydog Posted February 15, 2009 Author Share Posted February 15, 2009 Looks like you guys with the pebble theory are probably right. The same problem happened twice this past weekend, both times when coming to almost a complete stop. Just a simple reverse action took care of the incident each time. I'm just confused as to why this problem only happened now, and not the past 1 1/2 years I've had the car. Link to comment Share on other sites More sharing options...
PeterJMC Posted February 15, 2009 Share Posted February 15, 2009 How do you get so many rocks in your wheels between the rotor and the pads? Link to comment Share on other sites More sharing options...
tdoggydog Posted February 15, 2009 Author Share Posted February 15, 2009 How do you get so many rocks in your wheels between the rotor and the pads? These are trips up to our local SoCal mountains. There is an abundance of pebbles on the ground - I'm not really sure why. Salt? Wearing of the asphalt? Link to comment Share on other sites More sharing options...
surolegga Posted February 16, 2009 Share Posted February 16, 2009 These are trips up to our local SoCal mountains. There is an abundance of pebbles on the ground - I'm not really sure why. Salt? Wearing of the asphalt? Don't know about there, but local municipalities around here will use "traction grit" when there is light/moderate snow with frequent plowing. They try to avoid salt when the situation may bring heavier snow and low temps for fear of heavy ice. Once the snow stops/slows and there is chance to clear to the surface, they will use salt. Highways are always heavily salted/cal. chloride/plowed only. At the end of the season, there is a near inch high pile of pebbles/mud dirt between the tire tracks on the back roads...takes a good month of spring rains to get the crap off. Lots of windshield replacements, paint chips. Link to comment Share on other sites More sharing options...
tdoggydog Posted February 16, 2009 Author Share Posted February 16, 2009 Don't know about there, but local municipalities around here will use "traction grit" when there is light/moderate snow with frequent plowing. They try to avoid salt when the situation may bring heavier snow and low temps for fear of heavy ice. Once the snow stops/slows and there is chance to clear to the surface, they will use salt. Highways are always heavily salted/cal. chloride/plowed only. At the end of the season, there is a near inch high pile of pebbles/mud dirt between the tire tracks on the back roads...takes a good month of spring rains to get the crap off. Lots of windshield replacements, paint chips. That's probably it. Link to comment Share on other sites More sharing options...
tdoggydog Posted February 15, 2010 Author Share Posted February 15, 2010 Thread revival. This pebble business is really starting to irritate me. It happens essentially any time I travel over loose gravel, causing the brakes to make this horrible grinding/screeching sound. This weekend I couldn't dislodge it by reversing and basically had to drive until the pebble was ground down enough to be spit out. Is there ANYTHING that can be done to prevent this? Does anybody else enounter this problem? Link to comment Share on other sites More sharing options...
eppley Posted February 20, 2010 Share Posted February 20, 2010 i got a noise that only comes when the brakes are hot. when i'm coming to a slow stop kinda riding the brake a bit i get a grindin noise. i brought to the dealer and they said it was the caliper after bout 5 times they said there was nothing wrong. finally they replaced it with a genuine caliper. its been bout three months and no noise Link to comment Share on other sites More sharing options...
tdoggydog Posted February 20, 2010 Author Share Posted February 20, 2010 Took the car in to a brake shop today. They inspected it and, as I suspected, pebbles are getting caught between the shield and the rotor. The parts are all in functional order, so he recommended I carry a long screwdriver on me to give it a little nudge should another pebble get lodged. Really, Subaru? Really? You couldn't have designed a shield with a tighter seal? Come on! Link to comment Share on other sites More sharing options...
