SubieSteve Posted December 30, 2008 Share Posted December 30, 2008 I picked up a set of Hawk Ceramics from autoanything.com and just got around to installing them on Sunday. When installing the front passenger set I noticed the metal spring tab was not in the correct position. It looks like it was a defective piece but still used (it didn't look damaged). I tried to bend it but it snapped off pretty easily. I installed the pad (needed to) and tested the car. It seems fine - but I'm not sure what the long term impact would be on the pad/rotor. Does anyone know the spring tab's purpose? Is it for noise reduction? Would it make sense to contact the retailer or the manufacturer for recourse? Thanks! Link to comment Share on other sites More sharing options...
Mr. Sinister Posted December 30, 2008 Share Posted December 30, 2008 Are you talking about the wear indicator? It's a little metal tab/clip that extends slightly past the metal backing plate that will contact the rotor to make a squealing noise to let you know that the pads are almost worn out. Looks like: http://static.howstuffworks.com/gif/disc-brake7.jpg Link to comment Share on other sites More sharing options...
SubieSteve Posted December 30, 2008 Author Share Posted December 30, 2008 No it's not the ware indicator. It's a springy piece of metal that rests against the bracket that bolts over the rotor. I wish I had picture. If I find something I'll post it. Link to comment Share on other sites More sharing options...
magnetic1 Posted January 1, 2009 Share Posted January 1, 2009 Are you talking about the retainer clips? The ones that attach to the caliper brackets do not come with pads. They are a OEM Subaru part that retains the pads in the bracket. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
SubieSteve Posted January 3, 2009 Author Share Posted January 3, 2009 That might be the one. I have the old pads so I'll take a pic sometime tomorrow. Link to comment Share on other sites More sharing options...
