boostedlegacy87 Posted December 8, 2008 Share Posted December 8, 2008 so my battery light, stop lamp light, and at oil temp light keep flashing on and off randomly (there is no constant sequence). its usually after i have driven it about 5 miles that it starts acting up. i checked and replaced the battery since i needed a new one anyways. so i know the battery is good, i checked the voltage on the alternator both by myself and by a tech at walmart. the full system test came up good, and the test i did myself read 13.2 volts from the cigarette lighter. so i know the alternator is good and stays consistant throughout driving. i plugged in the diagnostic plug located under the steering column and the "check engine" light flashed 7 times quickly with a second in between and then would repeat. is there a chart somewhere where i can find out what that means? any ideas of what could be causing this? thanks guys, -bill Link to comment Share on other sites More sharing options...
sliCCriC Posted December 9, 2008 Share Posted December 9, 2008 dose it happen when you hit the brakes also??? my 91 legacy was doing the same thing, it came down to replacing the alternator, all techs and codes said it was fine but it wasnt, i replaced it and it stopped flashing those lights. or see if you can tighten your belt. Link to comment Share on other sites More sharing options...
boostedlegacy87 Posted December 9, 2008 Author Share Posted December 9, 2008 ok ill try tightening the belt first. Link to comment Share on other sites More sharing options...
jonklein611 Posted December 9, 2008 Share Posted December 9, 2008 the blink is a pre OBD II code. Quick search should find it. Link to comment Share on other sites More sharing options...
Bdubs Posted December 9, 2008 Share Posted December 9, 2008 http://www.surrealmirage.com/subaru/engine.html#enginetip Here are the definitions for the OBDI codes. There is no 7, so I'm assuming it is a code 16? Check out the page on how to reset the ECU as well, they will stay stored in the memory until you clear them. Link to comment Share on other sites More sharing options...
boostedlegacy87 Posted December 9, 2008 Author Share Posted December 9, 2008 found out from wrxfanatics about the blink code. apparently i have a bad injector on cylinder three. as for the blinking lights, still not sure what is going on. Link to comment Share on other sites More sharing options...
sliCCriC Posted December 11, 2008 Share Posted December 11, 2008 are your battery terminals tight? check the ground to the battery & alternator. if they are dirty... clean them off with cokeacola and a wire brush. Link to comment Share on other sites More sharing options...
KnifeyMcShanker Posted December 11, 2008 Share Posted December 11, 2008 EDIT: Whoops, accidentally thought you had an OBDII, disregard this post Link to comment Share on other sites More sharing options...
boostedlegacy87 Posted December 13, 2008 Author Share Posted December 13, 2008 problem fixed. it was a bad alternator. got a stock rebuilt one from aarons subaru only in Seattle. 75 bucks...i love that place Link to comment Share on other sites More sharing options...
sliCCriC Posted December 17, 2008 Share Posted December 17, 2008 $75 with core exchange? Link to comment Share on other sites More sharing options...
SubaruLegacy 270k Posted April 19, 2010 Share Posted April 19, 2010 Looks like I've got something similar going on with my car. It's a 1990 Legacy just replaced the alternator because it was not charging the battery and it failed the alternator test at the auto parts store both in and out of the car. After replacing the alternator and driving about 500 miles the battery, stop lamp, and at oil temp lights came on. When I got home I turned off the car and on again and they were not on but this morning when I started the car they had come back on. Also I found that my headlights would not turn on. I guess I could have gotten a bad alternator. I'll check that after work today. Any other ideas what might be wrong? Link to comment Share on other sites More sharing options...
