panamajack Posted February 14, 2005 Share Posted February 14, 2005 Will there be any noise after installing a swaybar? I have heard that it may squeek if not greased properly. What about if it is installed to tight? Just want to know what I am getting into. Thanks Link to comment Share on other sites More sharing options...
SWortham Posted February 14, 2005 Share Posted February 14, 2005 It should only squeak if the bushings require grease but don't have any. Or, simply over time the bushings will wear out and they'll be squeaky then, but that's virtually inevitable after 10's of thousands of miles. I would suggest using white teflon grease or a special urethane grease on the bushings when you install it and torque it to the recommended specs, and you shouldn't have any problems. Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted February 14, 2005 Share Posted February 14, 2005 Be liberal with the grease and don't choke the bushings with the brackets. Other than that you may every so often check the bushings and make sure the grease didn't wash off. I've used Mobil 1 Synthetic grease and have not had any probs. I wouldn't worry to much about it. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
panamajack Posted February 14, 2005 Author Share Posted February 14, 2005 Where do you get the torque specs? Link to comment Share on other sites More sharing options...
Xenonk Posted February 14, 2005 Share Posted February 14, 2005 I doubt you can even choke the bushings anyways if they are the correct size. I think the torque specs are around 25 lbs at most. Keefe Keefe Link to comment Share on other sites More sharing options...
LandShark Posted February 14, 2005 Share Posted February 14, 2005 I doubt you can even choke the bushings anyways if they are the correct size. I think the torque specs are around 25 lbs at most. Keefe showing my ignorance here.....is that inch-lbs or ft-lbs? Link to comment Share on other sites More sharing options...
Rommel Posted February 15, 2005 Share Posted February 15, 2005 Panamajack - bring it over I'll install it for you Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted February 15, 2005 Share Posted February 15, 2005 I doubt you can even choke the bushings anyways if they are the correct size. I think the torque specs are around 25 lbs at most. Keefe In my Rx you could, tighten those puppies down too much and it looked like snot commin out a nose. Not so much on the GT. Just makin a point as to what could cause a squeak. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
SWortham Posted February 15, 2005 Share Posted February 15, 2005 showing my ignorance here.....is that inch-lbs or ft-lbs? I'm sure that's 25 ft-lbs. 25 inch-lbs would be way too little. Link to comment Share on other sites More sharing options...
PGT Posted February 16, 2005 Share Posted February 16, 2005 I am getting a knocking noise out of the front of my car - I only put AVO bushings in (no endlinks yet). Everything is tight.....maybe too tight to let the bar move laterally? Not sure I can get my torque wrench under there unless I put it on a lift? One side Q - I greased the inside of the bushing only....should I have done the outside too? Link to comment Share on other sites More sharing options...
Rommel Posted February 16, 2005 Share Posted February 16, 2005 if you are having a knocking noise, the bar is probablly moving laterally and hitting something just my opinion Link to comment Share on other sites More sharing options...
