legacydispatcher Posted December 1, 2008 Share Posted December 1, 2008 My 07 2.5i has stock pads and rotors. Every morning they squeak for the 1st couple times I hit the brake. Any way to fix this? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 1, 2008 Share Posted December 1, 2008 Could be just a little rust. You might try "bedding in the brakes" I have found this works well. From 50-60mph hit the brakes hard until the ABS is just about the kick in, slowing to around 10mph but not stopping, repeat 4-5 times with in a very short distance. Drive the car a mile or so to let the brakes cool. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Denver133 Posted December 1, 2008 Share Posted December 1, 2008 How many miles does your 07 have? Is it an automatic? Link to comment Share on other sites More sharing options...
legacydispatcher Posted December 1, 2008 Author Share Posted December 1, 2008 How many miles does your 07 have? Is it an automatic? It is an auto and miles @40,000........ It only does it early in the morning when the brakes are cold...... Link to comment Share on other sites More sharing options...
SubieSteve Posted December 1, 2008 Share Posted December 1, 2008 Mine just started doing the same. Morning when backing out of the driveway only once, then they are fine. I have new rotors though..albeit with old pads. I just ordered Hawk ceramics - I hope they do the trick. Link to comment Share on other sites More sharing options...
ehsnils Posted December 1, 2008 Share Posted December 1, 2008 Just check that the wear on the discs are equal on both sides, you may have a caliper that's stuck. I had to replace my both front discs a while ago due to stuck calipers. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted December 1, 2008 Share Posted December 1, 2008 http://ecx.images-amazon.com/images/I/41XCS6BC19L._SL500_AA229_.gif ftmfw...this WILL work and should always be used when installing new pads. some ppl use antiseize, but it doesnt work as well Link to comment Share on other sites More sharing options...
