FPerron Posted November 30, 2008 Share Posted November 30, 2008 I posted this in the "Intake and Exhaust" forum, but got no response. I'm at stage 2.5 with a 40bb turbo tuned for Torco and Perrin turbo back. If I replace the Y-pipe and mufflers with a straight pipe (for track days, only), do I need to worry about running too lean? Link to comment Share on other sites More sharing options...
Spec B Posted November 30, 2008 Share Posted November 30, 2008 I am not certain, but I doubt you will need a retune and I am even more sceptical about the straight pipe making more HP. As far as I know, the Y and mufflers are not that restrictive and considering you are running (a very sweet, but small) VF40 turbo, I am not sure a straight pipe will give you much more HP than your existing turboback exaust. Link to comment Share on other sites More sharing options...
FPerron Posted November 30, 2008 Author Share Posted November 30, 2008 This is about weight saving:) Link to comment Share on other sites More sharing options...
Spec B Posted November 30, 2008 Share Posted November 30, 2008 ahhh...I think you will be fine with the existing tune. Link to comment Share on other sites More sharing options...
testes1010 Posted November 30, 2008 Share Posted November 30, 2008 As far as I know, the Y and mufflers are not that restrictive and considering you are running (a very sweet, but small) VF40 turbo.... Same map both runs, one with stock CBE(y-pipe/mufflers) the other run w/ Magnaflow CBE(3" Y-pipe, 2.5" dual Magnaflow mufflers): http://www.wrxfanatics.com/uploads/monthly_11_2008/post-367-1226970810.gif Thats a 13whp/18wtq gain using the same exact tune w/ aftermarket y-pipe & mufflers. I'd still be interested in seeing a complete stock tune LGT vs a completely stock tune LGT w/ aftermarket CBE. Link to comment Share on other sites More sharing options...
Spec B Posted November 30, 2008 Share Posted November 30, 2008 My thinking was that he is running a full turboback right now..not sure if you could squeeze that much of a gain above a turboback with a straight pipe. Link to comment Share on other sites More sharing options...
testes1010 Posted November 30, 2008 Share Posted November 30, 2008 My thinking was that he is running a full turboback right now..not sure if you could squeeze that much of a gain above a turboback with a straight pipe. ^I agree. I just making note that the stock y-pipe & muffler are a restriction. Link to comment Share on other sites More sharing options...
Spec B Posted November 30, 2008 Share Posted November 30, 2008 ^ BTW, I can't wait to see your power numbers when you get a DP! Link to comment Share on other sites More sharing options...
Infamous1 Posted November 30, 2008 Share Posted November 30, 2008 As long as you have adequate fueling already you will not need to worry about leaning out, the way fueling is calculated the exhaust will have no effect on it. Link to comment Share on other sites More sharing options...
FPerron Posted November 30, 2008 Author Share Posted November 30, 2008 Thanks, guys. Link to comment Share on other sites More sharing options...
testes1010 Posted November 30, 2008 Share Posted November 30, 2008 ^ BTW, I can't wait to see your power numbers when you get a DP! Crucial DP & race pipe are in the mail from 2 members on here. I have the Crucial P&P&C'd manifold w/ Grimmspeed X-pipe and Crucial Uppipe on hand. Now I need to pickup some new oem gaskets & I'll be set. Link to comment Share on other sites More sharing options...
