macdarwin Posted November 28, 2008 Share Posted November 28, 2008 hi fellas, just a quick question... i am currently running an 18" Enkei with 235-40-18 tires in it I am plannning to just buy a lowering springs to drop it... Any chance i will run into problems from the size of my rims and tires + lowering springs? any good springs out there for LGT? Im just worrying about the tires will rub into the fenders...any ideas?? thanks. -Darwin Link to comment Share on other sites More sharing options...
SBT Posted November 30, 2008 Share Posted November 30, 2008 Depends what the offset on your wheels is. >50 you may rub on the inside edge (suspension-impingement), less than ~45 and you'll potentially be rubbing on the fender. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted November 30, 2008 Share Posted November 30, 2008 Are you staying with stock suspension or going with something else, i.e., Tokico, Bilsteins, KYB? That will definitely determine what springs you go with as some are made for stock suspension, while others will kill it, or make you want to do bodily harm to yourself for having installed them. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
itsme Posted November 30, 2008 Share Posted November 30, 2008 it depends on your offset, mine is 45mm offset I'm running 19x7.5 w/225/35/19 and have my car lowered on KW v.2 coil overs and I dont rub. My car is pretty low and I could post pix when I get home. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
macdarwin Posted December 2, 2008 Author Share Posted December 2, 2008 thanks for the replies. my Rims is Enkei RS+M and its 18". I bought the car with it and I dont know the offset. Is there a possible way to look at the Offset of my rims just by looking at it directly?? thanks again. Link to comment Share on other sites More sharing options...
itsme Posted December 2, 2008 Share Posted December 2, 2008 Somethime the offset is stamped on the wheel or you can just look on the web site. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
