snowboarder_lgt Posted November 26, 2008 Share Posted November 26, 2008 I have a 98 LGT and the window tint on the drivers window keeps peeling up in the front corner after i roll the window down a few times. Has this happened to anyone else? Im not sure what i should do. Link to comment Share on other sites More sharing options...
leggtnut Posted November 26, 2008 Share Posted November 26, 2008 I would recommend finding a good tint shop. Subarus have not come with tint from the factory (as best to my recalection) and it is likely aftermarket Tint. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
snowboarder_lgt Posted November 27, 2008 Author Share Posted November 27, 2008 I had the tint professionally done, it has a lifetime warranty, and they thought after it peeled up the first time they just needed to start the tint lower in the door panel but it didnt work, I even waited 2 weeks to roll my window down. Trying to figure out what could be the problem and if its happened to anyone else. Thanks. Link to comment Share on other sites More sharing options...
scoobydoobie Posted November 28, 2008 Share Posted November 28, 2008 happened on my 99 forester in the same location (drivers side front corner), but not on any of the other windows. Can't figure it out either. Link to comment Share on other sites More sharing options...
dudeondacouch Posted November 28, 2008 Share Posted November 28, 2008 is there a heat vent aimed at that area? Link to comment Share on other sites More sharing options...
snowboarder_lgt Posted November 28, 2008 Author Share Posted November 28, 2008 Ya, so far so good on the other windows. I will probably take apart the door and check it out. What would a heat vent do to hurt the tint? Link to comment Share on other sites More sharing options...
dudeondacouch Posted November 28, 2008 Share Posted November 28, 2008 It could have dried it out too quickly in that area during the curing process. (I'm not a tinter though, so I don't know if that would be bad. I'm just tossing out ideas.) Link to comment Share on other sites More sharing options...
snowboarder_lgt Posted January 13, 2009 Author Share Posted January 13, 2009 I figured out the problem, if anyone else has this problem: There is a small square piece of rubber that comes out at the bottom from corner. It is VERY tight and makes the tint peal up. The door panel was removed. Was thinking about cutting this piece out but the tinter just put the tint underneath it and way further down the door jam than it previously was. I will try to add a photo of the piece later. Link to comment Share on other sites More sharing options...
