merchgod Posted January 19, 2009 Share Posted January 19, 2009 Great explanation, thank you, guys! I do see some FLCK here and there, but usually it gets cleared after each 15-20 min drive. BTW, if IAM was lowered, how fast it can be restored? Usually I did not log IAM, just cheking it in LeraningView after each logging session. It was always 1. Could it be lowered during a run, and then restored to 1 again, before I check it in LV? Yes it is possible. You are lucky in that you can log knock sum - not all ECUs have this feature. I wouldn't even bother logging FBKC, FLKC, IAM - just check a learning view before and after the run and log knock sum. Or if you do want to log those and your ECU supports the engineer's logging parameters, then log the 1-byte versions. Link to comment Share on other sites More sharing options...
lepich Posted January 19, 2009 Author Share Posted January 19, 2009 then log the 1-byte versions - To produce log with more resolution? I do have 1 bit versions. There are no bad people, just differeent. Link to comment Share on other sites More sharing options...
merchgod Posted January 19, 2009 Share Posted January 19, 2009 - To produce log with more resolution? I do have 1 bit versions. Yes, you want to log the 1-byte versions if available unless you need the additional precision of the 4-byte parameters - which really isn't necessary with FBKC/FLKC as long as you realize the value represented is not going to exactly match the decrements/increments in the ROM editors (IIRC, 0.5 degrees steps for 1-byte FBKC/FLKC). You should always log IAM 1-byte regardless as the should be no difference in the value between that and the 4-byte version. Really, I would log only the knock sum and do a learning view before and after which will be adequate in most cases for tuning. Link to comment Share on other sites More sharing options...
black318i Posted January 19, 2009 Share Posted January 19, 2009 What is the difference between all of the byte versions? Link to comment Share on other sites More sharing options...
merchgod Posted January 19, 2009 Share Posted January 19, 2009 What is the difference between all of the byte versions? 4-byte versions have the highest precision - they represent the value exactly as used by the ECU (In fact, you are logging the exact address as used by the ECU). 1-byte/2-byte parameters are based on the original 4-byte parameter, but the ECU performs a narrowing conversion to reduce overhead and therefore improve the overall logging speed. The disadvantage is that there is less precision and in some cases, it results in a min or max limit even though the 4-byte parameter has no effective limit (that is not really a concern for engineer parameters (**) for turbo models except for Engine Load 2-byte/1-byte which will be limited to 4.0 g/rev). Link to comment Share on other sites More sharing options...
