MaStaMooN Posted November 24, 2008 Share Posted November 24, 2008 Hey all, Coming up on 50k miles on my car and im starting to feel the brakes shudder a little and I know I'm due for brakes regardless. I want to do a small upgrade without 'braking' the budget... Whats the best pad/rotor combo that would be as close to stock brake overall performance.. Looking for a stage 0/1 here.. front and rear pads and rotors. My car is Stage 2 plus Top Mount with TDC e-tune. Driving style is mildly aggressive I would say with very few bursts of asshattery. Thanks in advance. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
Mr. Sinister Posted November 24, 2008 Share Posted November 24, 2008 DBA blank rotors and Hawk HPS pads are what I'll most likely go with when it's time. Edit: I just checked and it looks like Porterfield R4S pads are available for our cars. I've heard nothing but good things about those pads. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted November 25, 2008 Share Posted November 25, 2008 get ahold of thekingofparts. Jeremy S will fix you up with a kit he is a vendor on this site. Cheapest I have ever seen for these parts was from him I put DBA4000 slotted rotors, Hawk HPS pads, and braided lines. Link to comment Share on other sites More sharing options...
magnetic1 Posted November 25, 2008 Share Posted November 25, 2008 We've been selling our OE-type rotors for a while now with great success. From street to track. Hawk HPS pads discounted with rotor purchase. http://www.liteswap.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=L&Category_Code=LGTSpecial Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Tarmac Junkie Posted November 25, 2008 Share Posted November 25, 2008 If you want to get the best bang for the buck. First, keep you're stock rotors, they will be just fine, just have them turned. Second, Flush you're old brake fluid with ATE Superblue, (12 bucks form tire rack). Third, buy hawk hp+ pads.This combo will cost between $150-200. The pads will feel better than hps but with more noise and dust. Link to comment Share on other sites More sharing options...
MaStaMooN Posted November 26, 2008 Author Share Posted November 26, 2008 Thanks for the posts. Looks like the Hawks are the favorite for pads... a stock replacement rotor should be fine.. will atleast replace the front rotors and maybe just the rear pads. Thanks for the info! Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
hakgwai Posted November 26, 2008 Share Posted November 26, 2008 SS lines + ATE brake fluid would make it feel better Link to comment Share on other sites More sharing options...
caramall2 Posted November 26, 2008 Share Posted November 26, 2008 If you're not tracking the car, etc., I agree...stock rotors should be fine (heck, several guys have tracked them). I've used Bobcats for daily driving and their fine. (In the summer on the street, if I'm pushing the car at higher speeds, I actually like XP-8 knowing I won't have fade issues. But most probably wouldn't do this as they're dustier, noisier, etc. On the track, I have XP-10s (have tried XP-8s but they were at their limit...did fine, but I just want at least one step up).) Link to comment Share on other sites More sharing options...
magnetic1 Posted November 26, 2008 Share Posted November 26, 2008 SS lines + ATE brake fluid would make it feel better Depends how old the car is. If it is brand new, SS lines wouldnt change the feel all that much. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
hakgwai Posted November 27, 2008 Share Posted November 27, 2008 ^ 05 lgt? Link to comment Share on other sites More sharing options...
magnetic1 Posted November 27, 2008 Share Posted November 27, 2008 SHould be ok. More aggressive pads would give you more of a difference in pedal feel. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
slimjoe Posted November 27, 2008 Share Posted November 27, 2008 Stock rotors and Hawk HPS pads. Flush your brake fluid while you're at it (ATE Super Blue or the yellow stuff, same thing, just different color) Link to comment Share on other sites More sharing options...
magnetic1 Posted November 27, 2008 Share Posted November 27, 2008 Stock rotors and Hawk HPS pads. Flush your brake fluid while you're at it (ATE Super Blue or the yellow stuff, same thing, just different color) Id use the gold or some other similar fluid. Skip the ATE Blue. It stains and turns everything blue! Annoying as hell. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted November 28, 2008 Share Posted November 28, 2008 I will probably run bobcats as I have experience with them, can anyone compare bobcats to hawks as far as life, dust and noise? There is a good deal on axis rear pads that I found, any problem running bobcat fronts and axis rears? How are the Hawk ceramics? Link to comment Share on other sites More sharing options...
magnetic1 Posted November 28, 2008 Share Posted November 28, 2008 I will probably run bobcats as I have experience with them, can anyone compare bobcats to hawks as far as life, dust and noise? There is a good deal on axis rear pads that I found, any problem running bobcat fronts and axis rears? How are the Hawk ceramics? Life is prolly similar to HPS, dust is not dark black, but there is dust. And noise is a possibility under light braking. Axis will be super dark black dust, but would pair well with Bobcats up front. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted December 30, 2008 Share Posted December 30, 2008 Can anyone comment on Hawk ceramics? Link to comment Share on other sites More sharing options...
djsnoops Posted December 30, 2008 Share Posted December 30, 2008 i got HPS pads just recently...they are great. and i have front + rear cross drilled + slotted rotors from here.. http://brakeperformance.com/site/brake_rotors.php?&dv=0408&ad=google Link to comment Share on other sites More sharing options...
magnetic1 Posted December 30, 2008 Share Posted December 30, 2008 Can anyone comment on Hawk ceramics? Less aggressive than HPS, but will last longer and dust less. djsnoops: when you are due for replacement let us know. We have similar but cheaper and our slots dont go all the way to the edges for better integrity. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
djsnoops Posted December 30, 2008 Share Posted December 30, 2008 will do. i was thinkin dba but they are way too expensive and i just love the cross drilled looks good on rims Link to comment Share on other sites More sharing options...
MaStaMooN Posted December 30, 2008 Author Share Posted December 30, 2008 Im going to go with new OEM front rotors and HPS pads all around I think. Should be able to pull that in for under 300 bucks. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted December 31, 2008 Share Posted December 31, 2008 Not if you buy Subaru parts. Link to comment Share on other sites More sharing options...
MaStaMooN Posted December 31, 2008 Author Share Posted December 31, 2008 LGT oem rotors = 130 for set of 2 HPS Front = 85 HPS Rear = 69 Total = 284 plus shipping. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted December 31, 2008 Share Posted December 31, 2008 Ah, I missed the front part, thought you meant four rotors, which is what I need to do. Can't decide, Bobcats or HPS, money is a huge difference for each. Are bobcats worth the extra dough? I had them on my WRX and loved them, but they didn't last all that long. Link to comment Share on other sites More sharing options...
magnetic1 Posted January 1, 2009 Share Posted January 1, 2009 Depends on what you wanna do with the car. Bobcats will definitely give you more feel and bite, but the HPS will last longer. SuperHawk, January special has rear slotted rotors on sale now too. We discount HPS with rotor purchase, but if you want Bobcats, I may be able to discount those for you instead. Lemme know if I can help! LGT oem rotors = 130 for set of 2 HPS Front = 85 HPS Rear = 69 Total = 284 plus shipping. Just to note, we beat that. We sell OE-grade blanks with HPS for less including shipping. Actually WAY less until prices just went up. Under $300 shipped for the whole shabang. We held off on price increases from Hawk for a while until we had to buy more at the higher price. (The setup was under $270 shipped last month) Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted January 2, 2009 Share Posted January 2, 2009 I need all 4 pads and rotors. 55k I don't think I can get away with just turning my original rotors, fronts were already done once. PM me your best prices, I don't track or autocross I just want good street brakes. I already have ss lines and valvoline synth fluid, thanks. Link to comment Share on other sites More sharing options...
